[FLYN] Posted October 8, 2006 Share Posted October 8, 2006 Flying Performance International is the only official online Hybrid & SABER dealer Flying Performance International official website www.flyn.com.au Check out the Hybrid & SABER official website at www.powerdigger.com SABER 60mm ELECTRONIC GAUGES SMOKEY LENS SERIES now for sale! On SPECIAL ONLY $150 each gauge SABER 60mm gauges are electronic blacked out gauges which have high responsiveness and refined designs. When the car is off they have a black face with no numbers on them. As soon as the car is turned on, the gauges light up in bright white with full effect. * SABER electronic gauges provide more accurate reading over the mechanical type gauges, giving you a peace of mind over the reliability of your rides. SABER full-line up: boost pressure in PSI (for turbocharged and supercharged engines), oil temperature, oil pressure, water temperature, and air / fuel ratio, all with SABER black face and white dials. * SABER gauge dials are invisible when the ignition switch is off. Once the ignition switch is turned on, a clear display appears with white LED illumination. A red emitting instrument needle pointer are used in the gauges to increase visibility at night and in low-light conditions. They also features built-in light dimmer function. * SABER gauge pointers are driven by stepping motor with a microprocessor, needle accuracy up to 0.1 degrees of movement. It provides a smooth instantaneous response for rapid acceleration of high performance vehicles. * The included removable gauge visor is for eliminating the virtual image of gauges reflected on the windscreen. * All SABER gauges are applicable only for 12V vehicles. * Each Kit also comes with gauge mounting kit, gauge visor, all wiring and a step-by-step instructions. Payment Instruction Postage & Handling = $15 freight Australia wide PAYMENT TO : FLYING PERFORMANCE INTERNATIONAL PTY LTD ST. GEORGE BANK LIMITED BRANCH NO. : 112-879 ACCOUNT NO. : 065766824 PLEASE you must give the bank your forum user name as the description of the transaction. That way it shows up on our bank statement with the amount you have sent us. So we can match your order with your payment otherwise there may be a delay for us to match the payment to your order! After you have made the payment, please you must e-mail us with your payment date & amount, your name & postal details. Once we receive your payment, we will inform you and send it at the same time. It will be packed and sent securely in boxes or bubble padded bags for best protection. Optional extra $48 SABER stainless steel mesh air filter $180 SABER 60mm electonic smokey lens gauges $259 SABER GDB WRX /STi air intake kit $49 HYBRID a set of 10 HOSE CLAMPS, 2.5", 2.75" & 3" $19 HYBRID SILICONE HOSE REDUCER, We have 3" - 2.75" / 3" - 2.5" / 2.75" - 2.5", you tell us the size you want. $17 HYBRID SILICONE HOSE, 3" / 2.75" / 2.5" / 2.25" / 2" / 1.5" STRAIGHT HOSES $7 FLYING SILICONE VACUUM HOSE $49 Flying bov $49 Flying boost controller $29 Flying boost controller $199 + $25 extra freight $189 Flying Rb20det / rb25det turbo manifold $149 Flying 180sx s13 r32 300zx camber arm $149 Flying s14 s15 r33 r34 camber arm $99 FLYING SKYLINE R32 R33 R34 RB20 RB25DET TURBO DUMP PIPE $25 FLYING OIL CATCH CAN HSD Suspension HSD coil-overs are used by 2005 Drift Australia champion Darren Appleton and many other prominent drivers in Australia. Now available only in the premium HR series, HSD coil-overs feature 55mm heavy-duty full-tapped dampers with 15-step damping adjustment. All models feature pillow-ball top mounts for easy installation and maximum control. Models with strut-type suspension also feature camber adjustment, while all models feature adjustable base height and spring seat height. HSD coil-overs are supplied with spring rates intended for club-level motorsport, drift and street driving. Harder or softer springs are also available at just $100 a pair. All rates from 3kg/mm to 14kg/mm are kept in stock. All HSD coil-overs come with a 12-month warranty against manufacturing defects. NISSAN S13 Silvia or 180SX $1549 S14 200SX $1549 S15 200SX or Silvia $1549 R32 Skyline GTS & GTS-t (GTS-4 available to order) $1549 R33 Skyline GTS25 and GTS25t $1549 R34 Skyline GT and GT-t $1549 R32 GT-R $1549 R33 GT-R $1549 R34 GT-R $1549 Z32 300ZX and Fairlady Z $1549 Z33 350Z $1549 TOYOTA JZX90 Mark II, Cresta, Chaser $1549 JZX100 Mark II, Cresta, Chaser $1549 JZA70 Supra (Also GA-70, MA70, MA71) $1549 JZA80 Supra $1549 SXE10 Altezza and Lexus IS200 **NEW** $1549 SUBARU GC8 Impreza WRX (MY94 to MY00) $1599 GDB Impreza WRX (MY01 to MY02) $1599 GDB Impreza WRX (MY04 on) $1599 SG5 Forester $1599 MAZDA FC3S RX-7 (Series IV and V) $1549 FD3S RX-7 (Series VI to VIII) $1549 MITSUBISHI CP9A Lancer Evolution (IV to VI) $1549 CT9A Lancer Evolution (VII on) $1549 HONDA EG Civic $1549 EK Civic $1549 DC2 Integra $1549 DC5 Integra **NEW** $1599 AP1 S2000 $1549 Link to comment https://www.sau.com.au/forums/topic/137822-saber-60mm-smokey-lens-electronic-gauges-saber-air-filter-49/ Share on other sites More sharing options...
[FLYN] Posted October 16, 2006 Author Share Posted October 16, 2006 it is how it looks when the gauge is off. Link to comment https://www.sau.com.au/forums/topic/137822-saber-60mm-smokey-lens-electronic-gauges-saber-air-filter-49/#findComment-2587014 Share on other sites More sharing options...
[FLYN] Posted October 19, 2006 Author Share Posted October 19, 2006 it is how it looks when the gauge is on. Link to comment https://www.sau.com.au/forums/topic/137822-saber-60mm-smokey-lens-electronic-gauges-saber-air-filter-49/#findComment-2599099 Share on other sites More sharing options...
[FLYN] Posted October 24, 2006 Author Share Posted October 24, 2006 these saber gauges are extremely accurate as they have been tested and well recommended by professional racing drivers including the V8 supercars. Link to comment https://www.sau.com.au/forums/topic/137822-saber-60mm-smokey-lens-electronic-gauges-saber-air-filter-49/#findComment-2612598 Share on other sites More sharing options...
