i have the 0.81 housing
OK, with that size housing you should be able to get decent boost at 4,750 rpm or so. You don’t need a dyno to tune the cam timing if you have a stop watch and your seat of the pants feel is tuned. You can try a few settings yourself and “feel” the results, look at the boost gauge or better still measure them with your stop watch.
Most times I find around 2 degrees advanced on the inlet camshaft and 4 degrees retarded on the exhaust camshaft works out pretty good for early boost build, without compromising top end power too much. So for a starter give that a try. Remember every car is different, so don’t be afraid to experiment around those numbers.
Keep in mind that you will be able to advance the ignition timing (not just the 4 degrees to make up for retarding the camshaft 4 degrees). My experience has been that you can get quite a bit more advance which helps again some more with the earlier boost build. I basically just keep advancing the timing until I see some knock on the PFC Commander or knock amp (whatever brand). If no knock readings available, then I use a set of chassis ears and listen for some pre-ignition. You will be surprised how much more responsive you can make it with a bit of fiddling on the ignition advance.
Warnings;
1. Be careful how much exhaust camshaft timing you test at they will hit the pistons. Remember on the exhaust stroke the exhaust valve is opening at the same time as the piston is travelling upwards. So make sure that you measure the piston to valve clearance if you want to try more than 3-5 degrees.
2. You will have to add some fuel (lots) as the boost build earlier, so keep an eye on the A/F ratios.
3. Pre-ignition at your power and rpm levels is BAD news, so make sure you listen carefully.
Hopefully that has been of some use, any questions, just ask.
:( cheers :wave:
hey thanks gary. Ill have a crack at the valve timing when i get to work in a couple of hours. if i could loose 400-500rpm off the full boost time, it would be a start. i use a HKS knock AMP for my knock detection, but on the job i have some chassis ears, as they have to be used when working on diesel engines (high comp mofo's). but so far on the PFC, my knock has not exeeded 7. My tune is a tad lean for my taste, on full boost i get a 11.8-11.9 ratio @ 79% duty cycle. but i have the timing expert collegue look over the timing, he does this sorta thing all day. for now i am happy with the on boost response of the car, it is just pushing constantly when you reach boost.
11.8 - 11.9 is fine, perfectly safe, just watch the knock, stay under 20.
You will get a bit out of the cam tiiming, but the resulting ignition timing that you can run is the big winner.
Don't be afraid to throw plenty of degrees at it, 5 - 10 degrees is common. On the R33GTST, I moved the off boost up 18 degrees in some places.
:) cheers :D
Edited by Sydneykid
well thanks gary, with the fiddling on the cam gears i now hit my full boost around the 4800ish. my advice to people with RB26 and cam gears, fiddle around with them, they help you alot. and also gary, while working on the ign map i was able to iron out some flat spots, so when moving to boost it feels way more responsive, and also the stopwatch trick prooved it to me with measurable numbers. i build my ful boos a full 0.8 secs earlier, the car pulls quite constantly towards boost, not like before when i would move like a donkey, and then run like a cheetah.
Glad to see you got the results Faid, just shows what is possible if you are prepared to go though the processes. A ~400 rpm improvement in boost build is always worth spending some time on.
:laugh: cheers :mad:
PS; I like that "move like a donkey, then run like a cheetah" I am gunna use that for sure.
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
