hi all this is my virgin post on SAU hope that someone out there can give us a hand
I've got an rb25de powered silvia and am looking to get the most out possible looking for things that people have done or know work below is a list of things already done. any and all help is appreciated.
custom made exhaust
custom made extractors
cams
cam gears
wolf 3D version 4
pod filter
custom cold intake
lightened flywheel
heavy duty clutch
Q45 throttle body
looking for really responsive engine and some more revs any ideas?
https://www.sau.com.au/forums/topic/137840-more-power/
  • Replies 50
High compression, lightweight bottom end? You've done pretty much all the bolt-ons.
The only other thing I can think of is an intake manifold with shorter runners. That will shift your power band up in the rev range, but I have no idea what an RB25DE bottom end will rev to before breaking.
https://www.sau.com.au/forums/topic/137840-more-power/#findComment-2567280
rb30 bottome end. get it prepped, but it will sit up a bit higher (taller block on rb30).
or just build the 25 to rev hard with new valve springs and a lightweight, built bottom end.
dry sump?
personally id do the rb30, you've got everything else to make a sweet RB30DE, just needs a bottom end! 7-7500rpm, decent compression, party time in a silvia.
https://www.sau.com.au/forums/topic/137840-more-power/#findComment-2568479
Sil25, what power is it making with those mods?
Have you had it dyno tuned, cause if you've just thrown the parts together you wont be getting the full benifit.
I've never found the 25's to be all that revy when compared to the 20's, probably just a capacity and compression thing.
What size exhaust?
You might want some bigger injectors and/or a fuel pressure regulator. A friend of mine has an RB25 with some mods, and she's had issues with the air/feul ratio, which has really killed her power output.
Cheers
https://www.sau.com.au/forums/topic/137840-more-power/#findComment-2573940
RB26 head with open ITB's
upgrade cams to 304 duration and higher lift
stiffer valve springs
Shave the head and use dome top pistons for around 12:1 compression
some port work
should make close to 200 rwkw
tuned length extractors and to a cat-less exhaust hanging out the side and you have one hell of an NA.
not to mention a lightened flywheel and upgraded diff.
thinking about those ITB butterflies makes me wet..
https://www.sau.com.au/forums/topic/137840-more-power/#findComment-2576437
as muh as i would love to crack the head open it is not a valid option at the moment because it is just to expensive.
the extractors that i had made are tune lenght to match the cams, i also have a hi flow cat.
I did some research into ITB's and couldn't justify the cost i went the Q45 option machined with a heavier spring. If this acts as fast as i hope it will then it should do just fine.
to put it in no uncertain terms getting the air fuel ratio right was an absolute b#$ch. it took the best part of 2 months. forgot to mention that before 600hp fuel pump and unpgraded fuel lines.
injectors are coming just looking for a good set of 440 or 444.
made 170hp at the wheels with exhaust, wolf, fuel pump, pod.
haven't done tune since the last round of work still sitting in the workshop, looking for around 270rwhp
it drives amazingly. Very responsive, smooth as silk to take off and power band is very long due to the down low torque. I strongly recommend this transplant for anyone who love the NA
hope that i answered all your questions keep the coments coming its appreciated and good to see there are others out there who respect what it takes to build a NA motor.
https://www.sau.com.au/forums/topic/137840-more-power/#findComment-2576514
true but it only good for a quater run. are you still considered NA if you have nos?
hmm.. its debateable hey...
it is some form of forced induction, but its not something thats always used.
my stance on it is that you can run nos and be NA, its just "another mod".
same with those that consider cars that run semi-slicks to be "track cars" to me is just another mod.
https://www.sau.com.au/forums/topic/137840-more-power/#findComment-2577665
In drag racing terms Nitrous is considered chemical supercharging in alot of classes... but its still naturally aspirated engine personally i would still conder it NA, stick a 75hp shot into it ull love it!! mine ran for years on it and still ran as good as the day i got it! i used to use it all the time too not just for racing, we got a bit silly with it and changed the tps activation position and started drifting with it :P
https://www.sau.com.au/forums/topic/137840-more-power/#findComment-2577792
How is injecting a molecule stored under pressure in a bottle that breaks down into oxygen and nitrogen in any way "natural"?
https://www.sau.com.au/forums/topic/137840-more-power/#findComment-2578488
Where do you draw the line between "just another mod" and any other kind of mod? Everything is "just another mod".
Not trying to be argumentative - I'm just really curious about the thought processes behind how manually adding a chemical not found in the atmosphere into the intake reconciles in people's head with the definition of "natural".
https://www.sau.com.au/forums/topic/137840-more-power/#findComment-2578504
Whats natural about an engine at all, or adding octane booster or different fuels. Your missing the last part... "Asperation" the engine still breathes on its on... the intake charge is under no pressure other then atmospheric... Therefore its still natural.
Going on your theory ram air intakes are the same as having a turbo...
Edited by NA_R33
https://www.sau.com.au/forums/topic/137840-more-power/#findComment-2578614
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
