My project 33 gtst
Previous Mods
3" flying dump front pipe
Stocko Ceramic Cat
3.5" cat back to 4" tip
Heavy duty Clutch
Stock motor top and bottom
Stock Fuel pump
Stock turbo set 7lb normal driving to 10.5lb every now and then right foot driving
Running stock tyres
Coilover suspension
heavy duty clutch UNKNOWN
Stock Flywheel
Apexi PFC
running motul 8100 xcess oils
Nulon Coolant
Hybrid FMIC
Platinum Plugs
Split fire coil packs
K+N Pod filter custom cover
Made 180 RWKWs with above mods
New Mods
Hks 3037 Pro s Turbo running 0.68 housing internal Gated turbo
Custom split dump pipe to 3" front pipe (Bloody hks housings have to be different)
Custom water lines braided oil line
Not going to change cat converter
Tomei 248 lph fuel pump
555 High flow injectors from deatchworks
z32 AFM and plug
Gates Racing Timing belt
Exeedy Clutch Rated 300 rwkws Thanks C+B
Running on stock top and bottom
Oh and i forgot stainless intake pipe once the gb has there orders
Metal Cat it is 700+ cfm Cheers batmbl
Future to do mods in no specific order
Cams most likely tomei poncams cheap less than 800 delivered
Slotted rotors
Better Wheels
Better Suspension i hate coilovers
Pineapples
Forgies + head p+p (internal motor work)
Better Front bar: (Somewhere amongst the others)
Previous Best of 180 rwkws
Expecting 240 to 270 rwkws cams dependent i say
All awaiting on compression tests and leakdown tests to how soon the project goes ahead if ok should be
good for november.
:thumbsup:
Comments welcome
Cheers devils
Edited by Devils_Advocate21
https://www.sau.com.au/forums/topic/137881-my-project-33-gtst/
Will potential power be power reduced? Yes. More Importantly your turbo will not be able to produce boost as "efficiently". This will result in increased lag and higher turbo temps. You can pick up second hand decent CATS for <$200. It's worthwhile investment which you will never have to touch again.
hmm interesting, you guys would be right hmmm awell cat it is then :) still the go ahead will be known date from friday arvo once i get comp/leakdown test done
So far so good, i mean its not consuming oil or turning it black before 5000 kms of moderate driving, not blowing smoke of any sort, so i can see from the small picture it should be fine, the large picture well will be known on friday guys ;)
I guess suggestions would be very much appreciated on the catco cats from bosimporting, which one would be ample for my needs also results if any would be great aswell cheers guys
A
Ok so my compression values are in and leak down values what do you guys think:
Cyl1: 155 8%
Cyl2: 155 9%
Cyl3: 150 10%
Cyl4: 155 12%
Cyl5: 150 12%
Cyl6: 155 9%
Since last dyno made 178.9 rwkws before front pipe install so still running standard front pipe and dump
Also did power run whilst doing comp values to see if still in tune, seems that it is and with the new front pipe being the 3" complete front and dump comes to a new value of 197.3 rwkws.
The difference in IT's was 39 before and new of 41 with this one
So i think it would be safe to say that my project should be done mid november now :laugh: woohoo
Cheers
devils
No mention of boost controller?
Assume you've already got one, but if not, you need to ensure you have something that will reliably hold boost if you're looking to push that amount of power, particularly on std internals...
Boost spikes = very bad news on std internals.
A few to consider...
Greddy Profec B Spec II (I have one of these - works well)
Apexi AVCR
Turbosmart Eboost II
Was running the hybrid boost controler. but have found its in effecient at holding bosot, although the hks turbo has an addjustable actuator on it i may just use that at the moment instead for boost control and later move to a better brand controller, will let you know how i go and keep you guys updated
Apexi AVCR
  • 3 weeks later...
The two of the latter ones best bet i say, pending your power goal, and big difference in prices. will post dyno results next week when all done, On another note, regarding the highflow cat, did anyone notice a Sound drop, either im going deaf(I dont think so) but have noticed that since i put the cat on, my exhaust note/loudness has droped dramatically, quiet to compare against what it was?? Go figure
Cheers devils
Me either, I'm torn between a 2835proS, the 3037proS, and the GT3076R, so atm all dyno results will help me decide.
Cheers Adam
Maybe your old stock cat hollowed itself out and was basically functioning like a punched out cat. So when you chucked the hi flow cat on, you put a bit more restriction back into the exhaust system and thus the drop in noise. It shouldnt be that noticeable tho imo even if ur cat was 100% hollow
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
