SAU VIC - Pizza Night
When: Wednesday 18th Of October (3rd Wednesday of each Month)
Time: Meet at 7:00pm
Where: Wiseguys Pizza. Cnr of Park St and Kings Way (See attached map)
Duration: 2 hours
Notes: This place has no dine in facility so we can goto the local park (on Park st) to eat
Pricing: Standard Menu Pricing applies
Event Info:
This is a social event which will be held monthly for our community,
Each month we will select a Pizza place to visit for dinner.
This will be held on the 3rd Wednesday night of each month.
This can also serve as an opportunity for members who can't make our monthly meetings on the Tuesday to come and get updates on anything and to also discuss any important topics.
It's also just to have some fun and enjoy some fine quality food. We are open to suggestions for locations so please do suggest some if you know of super cool pizza places.
Voting Info (Members Only):
Upon completion of the night you can email your votes (or PM) to me and I will collate them and tally up the scores.
At the end of our 6 month or 12 month period we will sum up all the points and see what the best pizza place in Melbourne is.
The voting or rating information is based on the following:
Food - Crust
Food - Taste
Food - Topping
Food - Presentation
General - Service
General - Shop Presentation
General - Value for Money
https://www.sau.com.au/forums/topic/137931-sau-vic-monthly-pizza-night/
We won't be going to albert park. Instead there is a local park (funnily enough on park st) less than half a block up from Wiseguys pizza so we can eat dinner there. Albert Park is a bit further away and has no local bins that I can think of. So it makes sense to goto the local park which has bins and a grass area. There are no seats so bring one if you want, upto your personal preference.
See you all tomorrow night
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
