Guys,
Took my GTR out to Mallala on the weekend and found that after a couple of hard laps the water temp was sky rocketing up to a maximum of 119 degrees!!! Having trouble understanding why it has gone so high with the cooling hardware I am running:
R34 RB26
Apexi big aluminium radiator
Nismo uprated radiator cap
standard viscous fan / shroud
Carbon full length UAS air guide
The car had no pinging at all (max 34 knock value on the d-jetro pwr fc), the oil temp thanks to ARC coolers went no higher than 80 degrees, and there are no leaks etc in the cooling system. I found under full noise the temp was increasing 1 degree every 10 or so seconds - and once I backed off to drive around and cool it down it took ages to get down to under 100 degrees. This temp is verified by 3 seperate sources so I believe I can discount gauge error (pwr fc / dash temp gauge and defi water temp gauge all within +-3 degrees)
I thought for one that the R34 runs a N1 pump on it, and the car behaves normally on the road with normal operating temp being 89 - 90 degrees although I believe this to be a bit high. Do these symptoms sound normal for GTR's on the track with similar mods/ hp to mine, or do I have an issue somewhere else. Looking for guidance as to fixing this from those with experience on the track with GTR's please, although come to think of it any help greatly appreciated!!!!!
Blue32
https://www.sau.com.au/forums/topic/137948-cooling-issues-please-help/
It does sound wierd that you are getting water temps of nearly 120 but oil temps of only 80. Normally they would be much closer since they both come from the same hot engine.... Only thing i can think of is ducting, need more air flowing through the radiator, maybe you have a big front mount in the way? WHere is your oil cooler located? Have you bleed your water system? no air?
something is seriously wrong with your cooling system. on the street yout temp should be between 80-85 max for water temp. 119 is nuts there would be pockets of it boiling for sure by then. start with a flush, and bleed. check thermostat operation. that should be a good start.
Thats a good point, make sure your thermostat is opening, always the simple things.
Thanks guys - I'll start with a thermostat change and go from there. The temp on the street today with ambient temps around 25deg was 89-90 without a/c! Gotta be something wrong with the thermostat I reckon. How do the GTR water temps go on the track normally? Maybe we could post up our experiences with water temps at the track vs ambient air temp on the day, cooling system mods, and power the car is producing? Then we could all easily have a benchmark to check against and beable to tell if the cooling system is doing its job properly??
Use this as a template if you like
Car:
Power:
Cooling system mods:
Water temp on street:
Water Temp on track (incl ambient temp):
CAR: 1990 R32 GTR
POWER: 350awkw
Cooling System: PWR213 radiator - cant remember thickness with twin thermo fans
Water temp street:80
Water temp track :95 highest ever after 15 laps of national QR track (ambient 32-track 48)
Oil temp : 100 and stable during 15 laps national track QR edit -forget to mention Greddy oil cooler
Edited by gtr660hp
no need to bin it straight away, put it in a bucket of hot water with a themometer and slowly add boiling water till you see the thing fully open, then note the temp. check the workshop manual and see if it's on target (should be around 78 degrees or there abouts).
my GTR
270kw atw
stock radiator, stock thermostat
massive Greddy oil cooler ducted in the passenger side duct
water temp on street always between 78 and 82 even when hot outside, or punishing it.
on track never above 90.
oil temp varies a bit but on the street it's mostly around 80-85, sometimes up as high as 90 on the track it's been as high as 105, but water temp still faily stable.
also do you have a massive thick intercooler? if so that will be hurting your radiator performance badly.
and like it was said earlier, bleed the cooling system, there is a valve on the plenum, open it start the car and let it run until water bubbles out of the bleeder, then close it back up again.
Yeh, do the basics. Remove the radiator and give it the pros to give it a flush. Even then if the car is new to you it may not hurt to put a radiator flush through the engine and then top it all up with a good coolant.
Never mix brands or types of coolant...if your not sure whats in there then dump it all and start again.
The bleed the thing properly as Duncan suggested (I think thats all it is)
Does your aftermarket radiator have a shroud on it? Is it as well sealed as a std radiator to the supprot panel etc
Removed the radiator and sorted out my cooling issue on the weekend! It was a partly blocked radiator - containing calcium flakes which kinda look like rust flakes. Reverse flushed the radiator and in the end after I machined up an adapter to put the garden hose and the air compressor on the bottom hose, extracted some 2 or 3 table spoons of calcium build up. On initial removal, ran the garden hose through the radiator and the flow was pretty slow compared to after the flush out. Also completely flushed the engine using my hose and compressed air tool and found more within the engine. Also the thermostat in the car was a 65 degree one instead of the 76.5 factory nissan one. So now the car has a flushed system, with some tectalloy flush solution and water (until the weekend when I will reverse flush it again), a new genuine nissan thermostat and a new trust 1.3 bar radiator cap! Temps on the street today with a 28 degree ambient temp was 80-81 with the aircon on!!!!!!! Previously last week under same ambient conditions I was seeing 95-97 degrees.......... Calcium flakes due to previous owner mixing coolants - a lesson to be learnt for everyone on this one!
  • 1 month later...
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
