when justcars asks you "have had your license suspended in the last three years"
does that mean 3years from the date of the incedent??
i had my licence diqualified for 3 years, 4 years ago. i got them back a year ago.
can anyone tell me if that policy applies to me? i was obviosly off the road for that three years.
the date of my offence was almost 4 years ago?
all feedback and advice will be appreciated
https://www.sau.com.au/forums/topic/137965-how-does-it-work/
Have you had your license supsended in the last 3 years ? NO
Have you had your license suspended in the last 4 years? YES
I would ask them the question. As if you need your insurance, and they say get a copy of your driving record, they might say you lied. So ask them that way you are 100% sure.
See I think as your licence has been suspended for 2 of those 3 years, then thats a yes it has been to that question.
i asked them this exact question a couple of weeks ago, and i was told that its from the date of the incident which caused you to have your license suspended, not the date of when your license was suspended (usually a later date, not on the spot)
but to make sure you should call them it will take less time than it did to post up here, and you will get a sure answer straight away.
hmmm heres a question for you.
I will soon loose my licence (tomorow) for loss of points on a double demerit weekend, 80kph, 60kph for 40m then 80km again, double lane highway with a 4m island separating the other side of the highway with another 2 lanes in opposing direction, wanker was sitting behind the trees with his gun and the fact that i let of throttle to decellerate instead of braking means I now have $150 and 6 points... anyway, do I have to adv my insurance company to keep my cover or will it blow up in my face if my car is involved in an accident with the other person listed on my poilcy?
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
