From what I've read people do it to reduce the cooler pipe length and increase response.... at the same time I've read it reduces torque and increased the power band up higher in to the rev range so weather it works or not im not sure.... most likely a decent tune needs to be performed after installing one.
Edited by MintR33
https://www.sau.com.au/forums/topic/137976-custom-plenums/#findComment-2569781
the stocker is great for decent power, but the less piping the better/neater, plus the pipe does not have to cross over a hot engine with a front facing plenum... on a relatively stock motor a bigger plenum can hinder performance, but on say 350rwkw+ i believe it can help alot
ben...
https://www.sau.com.au/forums/topic/137976-custom-plenums/#findComment-2570221
waste of money.
When you can make over 300rwkw on the stock one
why change it? Doesnt pose a restriction or hinder the car at all
first everyone says u hit a brick wall at 300rwkw and now its over 300....man i wish someone would make u there mind...
http://www.skylinesaustralia.com/forums/in...32285&st=40
https://www.sau.com.au/forums/topic/137976-custom-plenums/#findComment-2570754
eh? You dont read/understand english very well.
Might i suggest you go and re-read the thread
We are waiting for a lot of R&D to backup the dribble you carry on with.
https://www.sau.com.au/forums/topic/137976-custom-plenums/#findComment-2571692
    • I have one and it was at ~43.5PSI.
    • Put a pressure gauge on the fuel rail.
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
