ouch... :D
btw not sure if yours is a S1 or S2 R33 but there are a set of R33 S1 head lights for sale in the FS threads brand new..
Its a series 1 Vic.
I dare say that will cost more than $3k to fix - You could try speaking to a few of the panel shops that support SAU including Vision Smash Artarmon and Xclusive Colours
https://www.sau.com.au/forums/topic/137989-smashed-my-car/#findComment-2568894
my advice is talk the other people out of going through their insurance company. tell them to take it somewhere and get a quote (or even better, 2 quotes), and if you are happy they can have it repaired up to that amount. last thing you want is the insurance company on your ass for the $$$, and be sure that if it's repaired by insurance company, knowing they are not footing the bill you may find a bit of a surprise.
https://www.sau.com.au/forums/topic/137989-smashed-my-car/#findComment-2569124
I'm another vote for Vision Smash Repairs.. they repaired my r33, they are repairing my daily driver, and will also be doing my silvia (and before anyone asks, no i didn't stack it.. just a little cleaning up is needed)
I was really really impressed with them.
Liz.
https://www.sau.com.au/forums/topic/137989-smashed-my-car/#findComment-2569131
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
