My crank angle sensor still have a sticker on 1 screw. Does it mean that my timing belt hasn't been changed??
Seller told me that timing belt was changed. By looking at the sticker here, it looks like the stock sticker.
Can someone confirm the sticker.
i have 100000km on my R32 gtst.
So i guess it is time to change.
If the timing belt has been changed or a 100,000km service has been done, there should be a sticker with the date it was changed and the kms when it was changed. This should be located at the top of the cam cover.
See here for more info: http://www.skylinesaustralia.com/forums/in...&hl=sticker
The sticker in this pic means that it is "recommended" that you change it at 100,000kms
i dont recall ever seeing that sticker on a CAS. it's most likey just there to stop people adjusting the timing once it was set. you could be right though. was there any receipts or service stickers to indicate that the timing belt HAD been changed?
No, i dont have any service record. Seller said it was changed but i dont believe that.
There is a sticker on the radiator, but i believe it is to show that the radiator liquid flush got change.
No sticker on the timing belt cover.
I do believe that the sticker on the screw of the CAS is stock.
I remember seeing a low km skyline and it got that sticker on the screw that looks fresh from the factory.
Is it easy to remove the timing belt cover? I would like to have a look at it, but im afraid to mess up with the timing from the CAS.
My CAS has the same sticker/tape. It had 68,000km on a wound back odo when I picked it up. I have no idea if my timing belt has been changed.
doodz not everyone has a 100,000km stamp. I'd be surprised if anyone other than Nissan stamped the head during that service.
the sticker is broken so the sensor has been moved or taken out
the sticker was broken on the side, probably due to its age.
if you look carefully in the picture, you can still see a part of the sticker covering the screw.
I doubt that someone will put back the sticker after opening the CAS.
yeah, no-one would use a screw driver to undo bolts. well no one smart anyway :teehee:
if it's broken on the side then it you be a safe bet to say it's been removed. all that means is that someone has removed or loosend the CAS. still doesn't tell you if the timing belt was changed or not.
you are right! :) No one will remove it with a screwdriver. :(
Now i still want to check if the timing belt was change.
Can someone tell me if it is easy to remove the CAS?
Just unbolt and mark down where the bolt sit, and remove?
Then put back at the same position??
Yes but you will have to check timming with a light to make sure its 15 degrees .
i have all those stickers all over my rb20det
it pretty much liek those seals on panadol cases i guess LOL
oi why is the a mitsubishsi (cant spell) symbol
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
