This car is an immaculate example of an original R32 Gts-t type M (Type M -sports brakes and suspension) RB20 Turbo. The car has been regularly serviced and maintained throughout ownership and has recently had a major service. Climate control, power steering/windows/mirrors, Autometer boost gauge, blow off valve , boost controller , BRANT alarm system with central locking and immobiliser, Kenwood head unit, New Exedy Sports Clutch, Hi Tech Muffler and 4 brand new tyres..The car has just been renewed with a fresh 1 YEAR REGO! Along with the sale comes numerous extras... call for info! This is an untampered example which speaks for itself! Very smooth and reliable! a great car for any enthusiast. ..$12000
Make NISSAN
Model SKYLINE
Series HR32
Year 1991
Colour Midnight Blue
Body type Coupe
Transmission 5spd Manual
Price $12,000 AUD
Contact Details.. 0414287402
Edited by N/A is not an option
https://www.sau.com.au/forums/topic/138049-sold/
Hey, can you tell me how the Type M suspension and brakes differ from the regular Gts-t? I realise this may be a bit of a skyline-noob question but I'm hoping you can answer all the same as it's listed as a selling point. Thanks.
https://www.sau.com.au/forums/topic/138049-sold/#findComment-2570344
  • 1 month later...
how much longer can you wait matey?
Sorry for the late reply... just wondering what u mean? I am in no rush for the sale.. although having 2 cars..with one sitting locked up waiting to be sold is a waste!
https://www.sau.com.au/forums/topic/138049-sold/#findComment-2761462
I'm not in Aus for another month or so thats why. Just curious how keen you were to get rid of it.
It's nice and clean - i'm after an R32 as daily for around that price.
I'll hit you back when I get home.
https://www.sau.com.au/forums/topic/138049-sold/#findComment-2762155
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
