I have an R33 GTS-t and was wondering was size MT's would fit comfortably?
I know of a set with mags for sale - they are 275/50/15 with 15x6.5in wheels...
my drive tyres are 265/35/18 with 18x9.5in wheels & they just clear the lip under wheel arch (car lowered slightly)
the 275's are a good buy (as wheels this size are hard to pick up too) but don't wanna risk buying them if they don't fit...
does anyone have this size fitted to their R33?
any help would be much appreciated...
https://www.sau.com.au/forums/topic/138071-mickey-thompsons/
255/50/16 are best suited to your car, anything larger would be overtyreing the car. They also fit on 300zx alloy rims. can find them somewhat cheaper. otherwise 235/60/15 to suit a 15" rim.
Is that width doable on a 6.5 inch rim?
Have a drag day this weekend and a mate offered to lend me his 275 MT streets. When I realised my 15 inch rim was 6.5 inch wide I laughed and said thanks for the offer but no thanks.
I thought the 235 would struggle on the 6.5 inch width let alone a 275?
275 are generally 17" in MT anyway. should run 255 on a 7" rim.
The common sizes are as follows, 235/60/15, 255/50/16, 275/40/17
Edited by BezerkR32
yep certainly is - i have seen them up close & there is no doubt about it - a
are 15x6.5in rim with 275/50/15 tyres
I have 275/40/17 MT ET Street Radials and a 17x9 rim. The MT Radials replace Nitto 275/40/17.
With the above size on a GTS25t you will NEED to lip the rear guards if you want minimal/zero neg' camber.
  • 4 weeks later...
Whats the offset of your rims? Im thinking of running the 275s on 33gtr rims which are +30 offset but i doubt they will fit..
    • Just buy a BMW if you want that... You can then choose whatever engine of theirs you want 😛
    • Clear vinyl wrap or clear coat?
    • There really needs to be an ODBII item that can play intake noise through speakers, synchronized with your current RPM and TPS%.
    • Worth most of the $50k alone!
    • So, we now have a straight and clean boot lid inbound and the car goes in for paint, again, on Wednesday, and will be ready on Friday, all ready to get cams and stuff on Monday  And by straight and clean.....I mean a brand new OEM one that cost..... $1300....😪 Sadly there's no clean undamaged used soft top version available, plenty for the power retractable hard top versions though, which is arse and makes Mark have the sads I could have waited longer, until a NC sort top boot lid eventually turned up, but I'm sick of waiting and said fark it and made it rain cash, meh In other naturally aspirated news, one of the guys at work brought in his old Corola which had a 4AGE in it, really nice clean car with lots of mods, including ITB's, man that things induction noise sounds sick with all of the dorts that makes you smile......maybe the NC needs ITB's, yeah, basically for the noise they make, but they're pretty expensive, but, they sound so damn good I may bring this up when I drop the car up on Monday, and by may, I mean I will🤣🤑🤪🤣
