I have an R33 GTS-t and was wondering was size MT's would fit comfortably?
I know of a set with mags for sale - they are 275/50/15 with 15x6.5in wheels...
my drive tyres are 265/35/18 with 18x9.5in wheels & they just clear the lip under wheel arch (car lowered slightly)
the 275's are a good buy (as wheels this size are hard to pick up too) but don't wanna risk buying them if they don't fit...
does anyone have this size fitted to their R33?
any help would be much appreciated...
https://www.sau.com.au/forums/topic/138071-mickey-thompsons/
255/50/16 are best suited to your car, anything larger would be overtyreing the car. They also fit on 300zx alloy rims. can find them somewhat cheaper. otherwise 235/60/15 to suit a 15" rim.
Is that width doable on a 6.5 inch rim?
Have a drag day this weekend and a mate offered to lend me his 275 MT streets. When I realised my 15 inch rim was 6.5 inch wide I laughed and said thanks for the offer but no thanks.
I thought the 235 would struggle on the 6.5 inch width let alone a 275?
275 are generally 17" in MT anyway. should run 255 on a 7" rim.
The common sizes are as follows, 235/60/15, 255/50/16, 275/40/17
Edited by BezerkR32
yep certainly is - i have seen them up close & there is no doubt about it - a
are 15x6.5in rim with 275/50/15 tyres
I have 275/40/17 MT ET Street Radials and a 17x9 rim. The MT Radials replace Nitto 275/40/17.
With the above size on a GTS25t you will NEED to lip the rear guards if you want minimal/zero neg' camber.
  • 4 weeks later...
Whats the offset of your rims? Im thinking of running the 275s on 33gtr rims which are +30 offset but i doubt they will fit..
    • Interesting.  Great info. thank you.  Give a few days to get that name plate.  I have a busy life most weeks.  I will be in touch.
    • Strange your posting about this being an issue. Move the harness or change your wheels or run more camber etc. Have the thing not touch the thing so it doesn't destroy the thing.  Short answer, no. Slightly longer answer, the factory fuel gauge is measuring resistance. You need to wire in the FPG fuel level sender into the original factory fuel level sender wiring.  I drew you a picture to explain this one The factory strainer is quite long, reaching down into the bottom of the tank. Safe bet your aftermarket fuel pump has a little baby sized strainer that probably doesn't even point down towards the bottom of the thank.  Solution, move the pump lower down in the tank, or fit a longer strainer, or do both. I did both, I've run my tank down to 5L remaining and the car still drove fine.
    • S2/3 GT-R is the same as S2 GTS-t The SRS airbags module in under the centre console. The S1/S1.5 GTS-t and S1 GT-R had the module built into the steering wheel. FWIW, I have a S3 GT-R wheel in my S2 GTS-t shit box. Same airbag plug, airbag light goes on then off, meaning all systems are go. S3 GT-R has red stitching, that's about it.
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
