I have an R33 GTS-t and was wondering was size MT's would fit comfortably?
I know of a set with mags for sale - they are 275/50/15 with 15x6.5in wheels...
my drive tyres are 265/35/18 with 18x9.5in wheels & they just clear the lip under wheel arch (car lowered slightly)
the 275's are a good buy (as wheels this size are hard to pick up too) but don't wanna risk buying them if they don't fit...
does anyone have this size fitted to their R33?
any help would be much appreciated...
https://www.sau.com.au/forums/topic/138071-mickey-thompsons/
255/50/16 are best suited to your car, anything larger would be overtyreing the car. They also fit on 300zx alloy rims. can find them somewhat cheaper. otherwise 235/60/15 to suit a 15" rim.
Is that width doable on a 6.5 inch rim?
Have a drag day this weekend and a mate offered to lend me his 275 MT streets. When I realised my 15 inch rim was 6.5 inch wide I laughed and said thanks for the offer but no thanks.
I thought the 235 would struggle on the 6.5 inch width let alone a 275?
275 are generally 17" in MT anyway. should run 255 on a 7" rim.
The common sizes are as follows, 235/60/15, 255/50/16, 275/40/17
Edited by BezerkR32
yep certainly is - i have seen them up close & there is no doubt about it - a
are 15x6.5in rim with 275/50/15 tyres
I have 275/40/17 MT ET Street Radials and a 17x9 rim. The MT Radials replace Nitto 275/40/17.
With the above size on a GTS25t you will NEED to lip the rear guards if you want minimal/zero neg' camber.
  • 4 weeks later...
Whats the offset of your rims? Im thinking of running the 275s on 33gtr rims which are +30 offset but i doubt they will fit..
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
