Hi People
I'm about to tune my car and i just want peoples opinions and reasons. as stated above which do you think gives a better tune dyno or road tune what are the advantages of each other than having a print out saying how much power you have and which will five me the more complete tune with the most power.
Cheers
anthony
Edited by black sky
https://www.sau.com.au/forums/topic/138079-dyno-or-road-tune/
Dyno
You cant hope to safely achieve the speeds/loads etc thats required on the street.
and temperature as chances are you will be doing it at night
ie hot track day comes along and tune goes bye bye
Edited by konect
I dyno tune, then take it for a run o the street to setup the accel pump settings and light throttle/ cruise settings, as you cant access these very light throttle points on the dyno. As for the tune changing at night, any good tune should not change day or night, as the computer has builtin air temp/density compensation.
I pick the hottest shittiest days and road tune mine. Just out of the way of the blue boys though.
hahaha!!
lol, both tunes Ive had done were in middle of an Adelaide summer, on a Dyno run by a Professional Tuner. 3rd tune will be exactly the same.
The more cars I tune myself, the more I become convinced that road tuning is essential. It is simply impossible to duplicate all of the conditions that you get on the road on the dyno. Plus (even if you could) it would cost a fortune to do a full tune on the dyno as it would involve hours and hours.
Let me give you a racing example. The V8 Supercar team I was with at Bathurst last week tune each and every one of their engines individually on an engine dyno over several days each. What they end up with is a PERFECT tune, for the dyno room in those conditions. When the car arrived at Bathurst the very FIRST thing the engine tuner did was check the lambda readings on the telemetry over the first 5 or so installation laps at the circuit. Then he made some adjustments to correct for altitude and atmospheric conditions. The drivers reported no noticeable increase in power (the telemetry showed no increase in acceleration as well) but they noticed improved driveability (eg; throttle response). He also spent a little time trimming the fuel economy to try and save time in the pits, refuelling.
Exactly the same logic applies to a road car tuned for driveablity and economy. Tuning for power on the dyno is the best method, but that is only one of the things that REAL tuning means.
So I will continue to do what I do now, tune the cars on the road (or the track) for power, response, driveability and economy. Then stick it on the dyno and fine tune the power.
:laugh: cheers :mad:
too true sk.
Driver: "hey man, the cops are chasing us"
Me: Good, now you have an excuse to hold in flat in 4th for me so I can finish trimming the fuelling up top..."
Edited by The Mafia
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
