Its not a voltage problem for many reasons...
1) If voltage was dropping the fuel pump would slow down so it would be leaning out at 5000rpm not richening up
2) If voltage was dropping and causing your ignition system problem, it would be misfiring and you would definately feel/hear this
The trial ECU means its been modified to certain paramters (probably to suit the stock setup) that would be useless for how your car is now setup. 99% of the time these Japanese modified ecu's use an epoxied eeprom meaning you cant retune it (its possibly even why it needed an engine rebuild as the Japanese are renowned for cranking up the ignition timing which doesnt work to well with our fuel).
Get a Power FC and I will bet money on it that with a decent tune your problems will be solved. If you spent $12k on the engine, you really shouldnt be stinging on other areas, its dangerous.
Edited by Amaru
Well I've just been for a ride in it, it seems to me that it's a heat and load related missfire
the miss is always there at around 5,000 revs, but it seems to occur earlier in the revs when the engine gets more heat into it. It doesn't miss badly enough to halt the engine from revving any harder, it's also not a fixed miss in that it occurs constantly above where it starts - it doesn't. It carries on and farts a little bit, I actually had to almost have my head out the window to hear it. Doesn't really backfire at all when you back off, no more than I've ever seen out of any other RB anyway
It revs absolutely fine when sitting there in neutral.
I couldn't hear any pinging at all or other mechanical noises, it idles really smoothly, doesn't miss at all at idle.
I dunno to me it seems like it's a stuffed set of coils or the ignitor box but then how come it's only done it since the engine was rebuilt..... perhaps it's something like the crank angle sensor isn't quite set to where it should be and is messing with the timing? (Would that cause something like this?)
Edited by Bluprint
Heard of a lot of ignitors shittin themselves after an engine rebuild and performance tune. Especially the 100,000 kms mark seems to show the RB26 issues. However this seems it's hit a limitation @ 5000 rpm.
In the tune, cams dialled in properly?, coils. From what you say Mark it happens under load. I'd have to agree with you from my limited knowledge.
Anything blocking the airflow ?
What are the mods to this beast?
Mine was tuned not to exceed 5500rpm after the rebuild to run in.
Edited by Sinista32
i had a very similar prob with my r32 gts-t turned out to be a fauly ignigter coil. prob was it was hard to find because it was very intermitant. ed at integra even tested the coils wile i was there and couldnt find the prob. but when i took it to nissan in philip they found it was a fulty coil. so got a new one and it's been running sweet ever since.
John at Trojan
Ed at integra
Please see someone with half an ounce of Skyline knowledge
That’s not a nice thing to say considering that Ed has done allot of work on allot of the skylines that are in Canberra. Ed's a really nice guy and I have never had any probs with his work, as I stated when he tested my igniter coil I was standing right there as he tested it. It was intermittent so it was not his fault. As a technician I know how hard diagnoses can be some times and I usually find that the people out there who boast that they know the most normally know the least. And even if they know what there talking about the work is usually shonky as hell.
Without looking at the car we can only speculate as there are a number of thing s it could be. If you are running aftermarket turbos with an untuned (to your particular car setup then this could be the problem)a trial one is only going to be fine if your engine and turbo setup are the same as what it was originally mapped for. I would be checking the basics first fuel press,boost press, ignition timing at the revs you are talking about also make sure he has connected the ecu earth points correctly, check all coil packs as you can have a slight missfire which will not necessarily give you a seat of the pants miss but can limit revs.Amaru is correct they do not have a boost cut only speed cut. If your computer isn't mapped to your setup then on boost the AFM will not be sending the correct voltage and can adjust timing and fuel corrections dramatically.Also check for simple things like blocked Cat or muffler.
If you get stuck pm me and i will have a look at it for you
Come on guys, we should be supporting local business, mechanics is not an exact science as there are a number of possibilities for any one problem it is just a matter of process of elimination. Every mechanic would have made a mistake in their time and anyone who says they haven't is bullsh**ting. Being qualified myself, working for an import yard,performance shop,Qantas as an Engineer and doing all my own work on these cars i speak from experience. These cars are up there with the best of them on technology and gadgets and anyone who has had to use the workshop manual and wiring diagram on one (Translated Japanese) will understand how hard it is to diagnose some of these problems.
It is like anything if you have come accross a problem for the first time it takes ages to find but the second time round not a problem.
Give these guys a go, if you have a problem with something they have done let em know and i'm sure they will sort it. It's the only way we learn.
    • No. The simplest wastegate hookup, with no solenoid or other form of "boost control" (ie, control over your boost control, if you know what I mean) is a single hose, direct from the turbo outlet/hot pipe, straight and only to the wastegate actuator. It is that pressure signal that drives the wastegate to open, providing the boost control (and by "boost control" here, I mean, limiting how high it can go, which is essentially the spring pressure of the actuator). You only end up with tee pieces and alternate flow paths once you start adding things to the boost control system to allow you to determine how much of that boost signal makes it to the actuator. There are so many ways to do that that there is no single way to run the hoses and tees and the like. If you have a stock boost solenoid, then all it does is either allow all the boost signal to go to the actuator, or open up to allow some of it to bleed off. There needs to be a restriction in that bleeder to allow only a small amount to bleed off. And in a stock system, that would then be plumbed back to the turbo inlet (for "emissions control" reasons). That is actually what that nipple on your BOV return pipe could/would be for. If you have an aftermarket boost controller and solenoid, then the above is mostly true, but there is no need for a restrictor in the bleed, because the solenoid is pulse width modulated to create a variable bleed off. The air that escapes from the bleed can either be vented, or also returned to the turbo inlet. For emissions reasons it should be returned to inlet, but the amount of air being vented is so small that it really doesn't matter (either from an emissions perspective, or from an air-fuel ratio affecting perspective).
    • And other times you just need to go buy bigger injectors?
    • Yup. I actually just blew my turbo. LOL.  should have checked this thread before today. i also have no boost solenoid. so it should be...one line from wastegate to turbo inlet, and a T somewhere in that line that connects to the wastegate return pipe?
    • It's recommended, however I can assure you a good amount of people don't bother. FWIW, the OEM battery lasted 4.5 years and I changed it prematurely too, I reckon could have stretched it to 5 years.
    • Are you telling me I'm going to need a code reader etc to just change the battery when it dies...  Why did I let you talk me into allowing Kate to buy this car lol
