i reckon if the mesh didnt need to be there nissan would not have fitted it in the first place. car companys dont like to spend a extra cent when building cars so it must be there for a reason .personaly i think if anyone reckons there are big gains to be made by removing are kidding themselves
I've read the negative boost article and it makes a good point. They measured vacuum before and after the AFM and there was a fair difference, which became a smaller difference with the mesh removed. The manometer doesn't lie.
If there is gains to be had, it would probably only be had if you retuned the ECU to suit it. Next time someone gets their car dyno tuned, try with and without mesh see if it makes a difference.
curious..at such a high velocity, compressor spooling and such, do you still expect the flow to be laminar?
maybe closer to the wall...I think can be safely said that the flow is turbulent anyways....what does it matter if the mesh cuts the flow or not..
chances are the mesh are there to prevent larger particles going into the intake system stuffing up the turbo...
better the afm then the turbo..
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
