..... hey guys
i have just removed the mesh from my afm, and removal of mesh in ryco stock air filter.... the acceleration is unbelievable with it now real quick n fast... but the thing is i have to make sure not to clutch in too hard or else the revs go from 1500 all da way down to .500 rpm and bounces!!!!
when i reversed the car it started smoking black for abit den stopped
running TOO rich?... i cleaned the afm oready?
all this cause of a mesh ???
any help wud be good i dun think any1 has tried this if so helpp!! :(
https://www.sau.com.au/forums/topic/138147-afm-mesh-removal/
i wouldnt recommend doing any of those really... yes acceleration would speed up but it would be throwing ur afm readings out of wack.... every now and again ill take the pod off my car as i can run no afm but that usually doesnt stay long at all....id prefer to keep my motor clean
ben...
actually i read it on an article on eliminating negative boost arghh shit article
so put the mesh back in? and see wat happens or tuning time?
:( lol worth a try
p.s moh.. learn to drive n beat mark before telling me mate :sorcerer:
any ideas
Edited by Zas)-(
Mine was missing one side of the mesh when I bought it, and it runs rich (I think). I get bad economy, but not much smoke at all. (no more than your average family car) Don't know what it's like on boost though, I certainly can't SEE any smoke.
Maybe try resetting your ECU, so it can relearn? Dunno if that would help it learn the A/F ratio or anything, because once you're out of closed loop, the ECU switches to the fuel-maps.
I'm hoping an SAFC can fix that for me and gain a little more oomph.
which side is urs missing, i took out one mesh did little as i removed the other one and fitted it back on.. good on the acceleration but bloody eats fuel like cops on shi*t .... p.s one mesh removed makes a difference
hmm i will try re-setting da ecu man :laugh:
if not cover da mesh time ...till i can get a new ecu unit
Edited by Zas)-(
