on 98 (ultimate/optimax) previously had to pull boost back a touch to prevent higher knocks,
on 100 (extreme/Vpower racing) have been able to re-up boost to as previous yet rarely get a high knock.
(pfc is still tuned to 98 fuel as would hate to get stuck in stix with wrong tuning to fuel available.)
works for me,
john.
tyred on my R33 GTST S2 for the first time about a week ago (shell near garden city), it certainly feels a lot better, no mods just exahust and still stock ecu !!.....
and hense petrol is anyway 10 cents cheaper here in brisy then in melbourne (moved up 1 month ago)..the price still feels better.....
im pretty sure its now called v-power coz thats what its called in europe. sort of a would wide standard.
ps. anyone ever read the "new unleaded" brocher where it "gets you further"
down the bottom it says in a small disclaimer that the fuel used during the test is "diferant" from what is curently available localy lol so yah it doesnt get you further lol
i have a question - I pumped up with v-power today (had a quarter tank of ultimate left). Came to about 33 ltrs - but then it only came to 3/4 tank full :(
would there be something to do with expansion of the fuel or is it just that my guage is stuffed? Im guessing my gauge is stuffed.
Yeah sounds like the gauge is stuffed. Did your fuel light come on though?
nah cos i filled it up when there was quarter tank of petrol....its just wierd - i will see how it goes when i fill it next time (if i get to fill it before my next service). I do know that skyline fuel gauges are notorious for being faulty.
SK
With your head work, have you run it up on the dyno?
Have you found higher power figures, different boost curve, faster or slower to boost, better or worse economy and response?
Thanks
BASS
SK
Thanks
BASS
Hi, not on the dyno, I am road tuning it. At the moment, with the standard turbo, I have 10 psi at ~2,000 rpm because of the ignition advance I can use, +18 degrees (compared ot the default maps) at many load points. As a result the response is lightning fast.
As for ecomomy, it happily runs 15.1 to 1 A/F ratios at cruise (open loop), with absolutely zero hesitiation or surge. So I can confidenmtly change the lambda aim table when I turn closed loop back on.
:( cheers ;)
SK. So headwork is a good option on a car, if for instance you are bored and want to pull the head off and have get it tidied up?
You won't loose any grunt?
without changing valves and all that, do you see it as a good thing to do once you have done turbo, injectors etc etc.
How does it go on the $ / results graph?
Just going back to the title of the thread for a second while we wait for God to respond... I used some of this fuel on the track the other day.
I was expecting to be able to put some more ignition timing in it but knock levels didn't decrease with the change of fuel so I left it alone. I felt maybe 5 more rwkw. However much is the smallest amount I can feel using the seat-of-the-pants-o-meter.
  • 1 month later...
As postred in the other thread where you asked the same questions
Been using 100 ron in the R33GTST since January (almost 12 months). I put an adjustable FPR in recently to raise the fuel pressure and a GTR fuel pump. I checked the fuel lines at the same time and they are in perfect condition.
:D cheers :D
is it me or why do i still think that my car feels nicer and smoother and 'quicker' on Vortex 98 even compared to V power racing?
Car: R33 gts-t (auto) with basic mods
my best mate with a stock R33 Gts-t Manual has the same opinion?
Edited by dineth
  • 3 months later...
ive been running vpower now 4 about 2 months in teh 1st week the motor started to run cleaner rev more freely and this improved all week. ive gone bac and tried ultimate etc and
also fuel economy when drivin normally (not v often 4 me lol ) has improved (550 km per tank good? )_
those out there using the ethanol blends from the discounters beware there some dodgy servos (no way ? :( ) out there upping there eth blend to cut costs........
:rofl: cheers :rofl:
So have I. seems to be great.
I have a 100RON joint near my house..I only drive the car 1 time per week so the extra cost means nothing to me.
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
