Just for a laugh.
1985 honda civic
890kg
1.6l DOHC ZC (not vtech yo) jap spec engine implant. 130HP at the crank from factory.
Mods: Extractors
rev cut 7500
15.5 down at WSID
100HP atw (75kw) lol at R31 club dyno day
Don't have it anymore.
i got a chrysler gallant
its got a custom exhaust (i cut it myself)
single down drought carbie(vacuum secondaries dont work)
and blown piston ring
"power" my guess bout 30kw at the rears lol
  • 1 month later...
Model - Swift
Engine - G13B
Modifications - Extractors, exhaust, cold air intake, BD14 cams, cam gears, Enlarged throttle body, group A chip, remapped ecu, dog box, msd coil set,
Dyno tune results 54kilowats before, 88 kilowats after
there was man other mods i just forget,
high 14 pass.
  • 3 weeks later...
put the pulsar on my mates dyno last night. made about 82kw, about 2kw down on what it made on a different dyno about 6 years ago. plenty of power left in it though. AFR's are mid 11's. now to convince the missus to let me put a nistune on it.....
  • 4 weeks later...
Engine:VQ35DE
Car: V35 Skyline Coupe
Mods: Z-tube and pop charger, Plenum spacer.
Power: 177rwkw.
Putting the Exhaust Headers on monday and a grounding kit. Will do a new Dyno run sometime next week. :P Hopping for 185rwkw
Finaly got the car on the dyno after getting the extractors and light wieght pulleys.
191rwkw now. Pushing for 200 :rofl2:
  • 3 weeks later...
  • 1 month later...
Some history on the RB20DE in the rally car:
Come a long way from it's first run of 97.5kw!
Spec's are:
RB20DE (235,000km)
Independent throttles (4AGE)
Ported head
Cams (270 or 280° can't remember)
Link G4
8,400rpm Rev limiter inguaged 4176 times in 2 years. That's not counting bouncing off the limit either. Rev it much?! :)
Z32 NA with exhaust/extractors/pod/chip yielded 240kw
My R32 with similar mods dynoed 222kw.
Battling to extract more though.
Errrrm...i think you were meant to say horsepower...240rwkws is somthing like 320-330kws at the flywheel.
I think he's just talking crap as a Z32 NA will all that wont make 240rwhp/rwkw in any case.
Rb30e
Today I made:
97.5rwkw @ 120kph
321nm @ 88kph
Rev Limiter @ 6500rpm
Specs:
Stock RB30E
Stock Timing (+15)
91 Fuel
Extractors & 2.5" Exhaust, Stock Cat & 1 Muffler Before Diff
3" Intake Pipe, Cheap Pod, Custom Airbox & CAI.
Going to run it on 98 Fuel Next time & +20 Timing, aiming for 100rwkw, also need to sort out the issue with it running rich.
  • 4 weeks later...
94 r33
rb25de
stainless steel extractors, cat back, apexi pod.
95.7rwkw...
update today i got 101.7rwkw with new catbak and timing advance in 4th gear run
what size exhaust do you have from the headers? and what size from the cat back?
  • 1 month later...
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
