Just for a laugh.
1985 honda civic
890kg
1.6l DOHC ZC (not vtech yo) jap spec engine implant. 130HP at the crank from factory.
Mods: Extractors
rev cut 7500
15.5 down at WSID
100HP atw (75kw) lol at R31 club dyno day
Don't have it anymore.
i got a chrysler gallant
its got a custom exhaust (i cut it myself)
single down drought carbie(vacuum secondaries dont work)
and blown piston ring
"power" my guess bout 30kw at the rears lol
  • 1 month later...
Model - Swift
Engine - G13B
Modifications - Extractors, exhaust, cold air intake, BD14 cams, cam gears, Enlarged throttle body, group A chip, remapped ecu, dog box, msd coil set,
Dyno tune results 54kilowats before, 88 kilowats after
there was man other mods i just forget,
high 14 pass.
  • 3 weeks later...
put the pulsar on my mates dyno last night. made about 82kw, about 2kw down on what it made on a different dyno about 6 years ago. plenty of power left in it though. AFR's are mid 11's. now to convince the missus to let me put a nistune on it.....
  • 4 weeks later...
Engine:VQ35DE
Car: V35 Skyline Coupe
Mods: Z-tube and pop charger, Plenum spacer.
Power: 177rwkw.
Putting the Exhaust Headers on monday and a grounding kit. Will do a new Dyno run sometime next week. :P Hopping for 185rwkw
Finaly got the car on the dyno after getting the extractors and light wieght pulleys.
191rwkw now. Pushing for 200 :rofl2:
  • 3 weeks later...
  • 1 month later...
Some history on the RB20DE in the rally car:
Come a long way from it's first run of 97.5kw!
Spec's are:
RB20DE (235,000km)
Independent throttles (4AGE)
Ported head
Cams (270 or 280° can't remember)
Link G4
8,400rpm Rev limiter inguaged 4176 times in 2 years. That's not counting bouncing off the limit either. Rev it much?! :)
Z32 NA with exhaust/extractors/pod/chip yielded 240kw
My R32 with similar mods dynoed 222kw.
Battling to extract more though.
Errrrm...i think you were meant to say horsepower...240rwkws is somthing like 320-330kws at the flywheel.
I think he's just talking crap as a Z32 NA will all that wont make 240rwhp/rwkw in any case.
Rb30e
Today I made:
97.5rwkw @ 120kph
321nm @ 88kph
Rev Limiter @ 6500rpm
Specs:
Stock RB30E
Stock Timing (+15)
91 Fuel
Extractors & 2.5" Exhaust, Stock Cat & 1 Muffler Before Diff
3" Intake Pipe, Cheap Pod, Custom Airbox & CAI.
Going to run it on 98 Fuel Next time & +20 Timing, aiming for 100rwkw, also need to sort out the issue with it running rich.
  • 4 weeks later...
94 r33
rb25de
stainless steel extractors, cat back, apexi pod.
95.7rwkw...
update today i got 101.7rwkw with new catbak and timing advance in 4th gear run
what size exhaust do you have from the headers? and what size from the cat back?
  • 1 month later...
    • If the RB29 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
