Cant believe I could be f'ed doing this
http://www.djrperformance.com.au/dynographs.html
Very nicely inflated results there
and
oh look a Chassis dyno...not an engine brake
http://www.djrperformance.com.au/services.html
so
he was claiming rwkw's
  • 3 months later...
1989 Nissan Skyline R31 Silhouette
RB30E
GTS2 Extractors
3'' Straight Pipe
20 Degrees BTDC Ignition Timing
98 PULP
Also just going to mention that my car is over fueling and running extra rich so that would have taken some out of it.
2007 V36 370GT VQ37HR 3.7L V6 5SPD AUTO
Modifications:
Cat-back exhaust pipes
Hi-flow panel filters
Apparently car runs rich from factory, bit more power to squeeze out of it if I can lean of the a/f ratio a bit
Stock Power run done close to when I first got the car for reference:
  • 3 weeks later...
  • 1 month later...
+1
also love how the radiator hoses are put as a modification
I thought this thred was for dyno figures? apparently not.... Anyway, Ive only put down what was read out at the car show where the dyno run was done, And I thought the turbo r34 standard are 208kw and the gtr 280kw? From what I've read about a million times N/A RB25de neos do about 147kw standard?? is this wrong coz the thing will keep up with my mates boosted s14 no problem?
both the r34 GT-t and the GTR are quoted as having 206kw at the flywheel (all factory quoted figures are at the flywheel) however the GTR actually puts out more power. and yes, the non turbo is 147kw (again, at the flywheel) which would work out to be about 150hp at the wheels
  • 2 months later...
  • 3 months later...
  • 4 weeks later...
R31 Skyline Series III Ti
RB30E
Stock Motor Done Near 800,000K's - Runs A Little Off Beat
Runs a rusty old set of extractors with old stock exhaustand had 4.11 Diff ratio which was stuffed open wheeler "Just about to install 3.23 LSD"
New GTS1 Cam, Timing Kit, Plugs & Leads - Installed 6 Weeks Ago!
15" Ti Alloy mags
Does 10KPL Religiously & equates to almost 600K's Per tank
Am shortly contemplating in dumping the NA high comp motor that I've got with around 80,000K's on it and VLT auto trans that's only done a few hundred K's along with Hi-tech headers "Stainless" and 2-1/2" sports exhaust. WIll be interested in seeing if the figures change much along with the 3.23:1 LSD installed.
Just got my v35 350gt8 a week ago. runs 200kw at flywheel stock. Waiting on a few parts to turn up.
Used to have a na b18c type r powered crx with a few bits here and there running high 12s low 13s.
bout 180fwkw
Gonna try and beat that with the extra na displacement.
  • 1 month later...
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
