I have a 1999 R34 GT (manual) RB25DE
Put out 101.8 kW fully stock then put on a full Trust stainless steel catback exhaust with 80mm tubing and 115mm tip, and a full cold air intake kit (with a Trust Airinx pod filter), did another power run and the car jumped up to 118.7 kW. I thought that wasnt too bad really!!!!
Edited by MissR34
  • 3 weeks later...
1997 R33 GTS25 series 2
I just got the 33 dynoed on the weekend. Came out with 160hp/116KW at the rear wheels. Engine is completly stock, Only with cat back exhaust.
Also: My mechanic pointed out to me that it has a set of nismo racing struts on it as well, They were already on the car = win!
Edited by OBNXSH
new power figure
dyno dynamics
modifications: standard panel filter, coby extractors, 2.5" cat and 2.5" cat back exhaust, matty spry tuned safc2
power: 115.4rwkw
consensus: panel filter and an intake idea and i'd be done. wouldn't recommend going any further with power mods, despite the coolness of cams, cam gears, port and polish - costs would be astronomical for minimal gains, you would also be looking into a proper ecu to make the full use of them. extractors dont give any sort of peak power, but driveability and fatter mid range is very noticeable. with the retune reving is much smoother, power delivery is nice and "free", definitely a much better car to drive. peak power is only a number.
future mods: would stick to drivetrain mods; lightened flywheel, shorter diff ratio, lighter tail shaft - try to make the current power more useable.
does it have to be skyline...... 98 3.5 v6 Mitsubishi verada (4 speed slush box auto) with pacemaker extractors, lukey muffler mandrel bent 2.5 inch system + unichip = 130fwkw
  • Like 1
my r34 gt is now doing 119.9kW at rear wheels. just got extractors put on so going back in a couple of weeks (to allow ecu/sensors to adjust and do its funky thing). my car can now breathe!!!!!
Model: 1987 R31 Skyline Ti
Engine: RB30DE with VVT
Modifications: Extractors, exhaust, twin tb, safc untuned, billet f/wheel, reground surecams, 10.5 compression, 18 degrees timing, 98ron ultimate
Power: 150.9RWKW @ 172kmph an 507nm (374FtLb) torque at 144kmph
with more left in it, she's an economical daily but rich and restricted above 5000rpm so once thats tuned/fixed i'll be a happy camper
I built this engine and ran it in my 86 r31 Skyline station wagon . With a 4.11 locked diff , 195,60x14 radials @ 20psi , i recorded a best 1/4 mile of 14.15 @ 97.6 mph at Willowbank dragstrip 16-8-2006 .
Also at Lake Gairdner speed trials 2006 ,max speed of 141.18 mph ( 227kmh ) using 3.7 diif with .75 OD . ( had fuel starvation prob )
Well after yesterday.....
Model: 2000 R34 GTV Manual
Engine: RB25DE NEO
Good Mods: Fujitsubo Cat Back ( 70mm pipe ) - APEXi Panel Filter
Bad Mods: Starcorp Impul 18's w/275/35/18 ( fcuking heavy )
Power: 107.7rwkw
  • 5 weeks later...
Model: Z33 manual
Engine: VQ35DE
Mods: 2.5" catback exhaust (not entirely dual), intake manifold spacer, pod filter, Unichip
Power: 189.2rwkW
Mods: Above + extractors, high flow cats, modified intake plenum runners, increased redline, retuned Unichip
Power: 195rwkW
R31 Silhouette
RB30E Manual
S1 Cam, Powerchip, Extractors, 2.25" Exhaust with one muffler, no silencer, Hi Flow Cat
Heavy Duty Clutch, R33 Airbox with sealed cold air intake, LSD.
117rwkw 14.2 0-400m
Citroen Xsara VTS 2004 2.0lt XU10J4RS
Hi Flow sealed air intake, Tuned Mandrel Exhaust 2.25", Chip
114fwkw 15.0 0-400m
  • 1 month later...
Car: Aussie R31 GX
Engine: RB30e internally standard ie. standard head & cam
Trans: factory 5 speed
Mods: XF Falcon TB, 3" mandrel bent intake pipe with K&N pod, raising rate fuel pressure reg, extractors, 2.5" straight through exhaust with very high flow cat, advanced timing, 10mm leads, Exedy clutch & minispool.
Power: 108rwkw on a Dyno Dynamics dyno
Carl
  • 3 months later...
  • 1 month later...
pulled 115.6rwkw with a fuel problem.
need a new pump and change of fuel filter.
should be able to hit 120 with a bit of timing advance as well.
dynodynamics dyno @ unigroup engineering.
5zigen 2.5" catback exhaust & K&N Ms pod filter.
Edited by whyte
interesting figures,,,
for the record mine was totaly stock at 200.9hp (149kw)at flywheel and 140hp 104kw.@wheels(6500revs)
with 150lbft torque @ 5400 revs
from the comparisons on here and given that was stock with new plugs, thats quite high suprisingly.
Edited by Hesh
I know its not a nissan and not a skyline.... (i'm on here looking for power figures of NA 6's... actually in the market for a 350Z to modify NA style...)
My N/A BA XR6 Falcon puts out 194.3rwkw... @ 6800rpm
(192rwkw @ 5800rpm)
Currently has -
Nizpro CAMS
CAPA flash tune (by Nizpro)
Custom Twin Throttle Body setup (2x 70mm TB's)
Nizpro Custom Extractors
BF Turbo Exhaust
to Come -
Compression increase from 9.65 > 10.4
Intake manifold Phenolic Spacer
Individual Throttle Bodies (6x 45mm)
Port and polish
Custom Zorst with twin 2.25" metal cats
Retune...
for those who don't care about the falcons but are curious, the Barra 182 Engine stock is a 4.0L inline 6 with 182 Fly wheel kilowatts.
How much should I expect from similar mods on a VQ35DE?
Cheers
Edited by Guardian_aiur
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
