Model - C210 Series 1
Engine - L24S
Modifications - Extractors, 2in flowing exhaust.
Dyno results - 60rwkw @ 5400rpm
Stupidly advanced timing (didn't know)
unopened since 1978
  • 1 month later...
Make and Model - R34 Nissan Skyline GT Sedan
Engine - RB25DE NEO
Modifications - 2.5" cat back exhaust with lukey rear muffler, Cold Air Intake, K&N flat panel air filter, Super Spark Coil packs with Iridium plugs, Drift high flow fuel filter, Gates Radiator Hoses
Dyno Results (done with a bottle of octane boost and clean in the tank) - 177kw or 235hp :/
Engine - RB25DE NEO
Dyno Results (done with a bottle of octane boost and clean in the tank) - 177kw or 235hp banana.gif
lol which dyno did you use? Cause I wanna take my car there too!
Model - R33 Series 1 GTS
Engine - RB25DE
Fully Sick Mods - Stainless intake pipe, air filter, super sparks, iridium plugs - More mods with money in the future (bodykit adds heaps of power)
Skidpower - 103.6rwkw
  • 3 weeks later...
Can't see any entries here that have used Individual Throttle bodies on a VQ35DE engine...
If I've missed it, please reply with link... or just tell me the gains they experienced with this mod and\or combined NA mods.
Would be great help and would help keep me off the Force Induction route. Thanks!
  • 1 month later...
S14 SR20DE
Apexi PowerFC
Tomei 270° 12.mm cams
4-2-1 extractors, 70mm exhaust
RB25 AFM
Pod filter
122.4rwkw
I had this engine retuned last week after around 3 years of 8k abuse and 1 year of sitting in my garage
near identical except now it has a more street friendly 2.5 exhaust and a cat and is running off an s13 DET ecu
109.8 rwkw
  • 3 weeks later...
  • 2 months later...
Engine - RB25DE NEO
Dyno by DJR Performance in Taree NSW
Edited by Keith w
r33 gts
r34 rb25de neo + gearbox conversion
mini spool diff
new 2 3/4 exhaust
semi coil overs
heavy duty clutch
ceramic brake pads
different brake calipers not sure what from tho.
Engine - RB25DE NEO
Thats more than the turbo models put out with similar mods.
Would love to see the dyno chart with corrections shown.
  • 3 weeks later...
He clearly stated 177KW not RWKW
So he pulled his engine out and hooked it up to an engine dyno did he?
Well... since you are so on the ball, can you tell what the figures were? S.A.E? Net? what temp, what altitude etc etc.
Actually LOL @ the thought of some mechanic in Taree trying to wire in a factory 34 Ecu into an engine dyno room...with all the inbuilt security systems and shiz.
Wonder how well the perormance adding radiator hoses helped when hooking it up to the coolant tank.
im sorry, dont you think your asking the wrong guy for the figures???? if you want to know it, you better ask Keith w for it.
all im saying is read carefully before you make false assumptions. now Keith w never claimed that he made 177rwkw did he?
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
