Hey people this is my 1st post thought it would be a good place!
YEAR: 1984
MODEL: Skyline GT EX Facelift (with RB30DET)
BODY TYPE: Sedan
COLOUR: White
Edited by R30-RB30DET
for those of you with HR31's here is a link to the register from the R31 Club...
http://forum.r31skylineclub.com/index.php?topic=19090.0
please leave the details in both this thread and the one on the r31 forum.
Edited by rsx84
post-32896-1162953263.jpgHey all,
I just purchased a 1984 MR30 Hatch 'Ti' auto, stock standard L24e, only 130,000km...
Needs a few steering parts and tyres for RWC
The steering bits might be hard to come by... 'idler arm and ball joints are worn/loose"
The engine is pretty good, need more power thought of course! looking at a fully ported L28 conversion, with hope of a turbo later on, or a RB20DET, ( which might be easier...)
Will post up some more pics later....
And i really need help with these steering parts!
YEAR: 1989
MODEL: nissan R31 skyline series 3
BODY TYE: SEDAN
COLOUR: white.
MODS:
full sound system.
king springs low.
hyb shocks.
dba sloted disc front and rear.
k&n filter CAI intake.
adv timeing.
hight tech exstractors
2.25" exhaust.
chiped computer.
LSD
17x17 aus car bournouts.
YEAR: 1978
MODEL: C210
BODY TYPE: Sedan
COLOUR: Orange
Just fitted GT-E Tail-lights :(
Year: 1990
model: r31 GX
body type: wagon ^^
colour: white
Did have:
Year: 1983
Model: KHR30 GT-ES Paul Newman Version
Body type: Coupe
Color: Blue Pearl
Swapped for
Year: 1984
Model: GT-EX Turbo
Body type: Sedan
Color: White
Matt,
I don't know wether you want to include this as relevant, but my PNV is colour code 441, which is 002 white over 028 grey metalic.
And George Bryants old car that you list under ??? is colour code 434, which is 111 Dark Blue over 028 Grey metalic.
And although some are plated LATE 83, ALL Paul Newman Versions were manufactured in series 2 livery and marketed and made for the 84/85 market ONLY.
Cheers, D.
Matt,
Cheers, D.
that kind of info is better listed in a thread devoted to the PN version...
Cheers anyway, Matt...
YEAR: 1988
MODEL: Nissan R31 Skyline Silhouette GTS1 #166 of 200
BODY TYE: SEDAN
COLOUR: Classic White.
MODS: Stock .... NSV optioned... (16" rims, 2.25 exh. Extractors, Bilstiens, bigger brakes, sg.1 cam, scheel bucket seats... etc)
The owner of:
Year: 1983
Body type: Coupe
Color: Blue Pearl
Is drift_orcons from www.skylinesdownunder.com
the car is located in Christchurch, New Zealand.
I know this isnt a spotted thread but these are worth a mention
today I saw 3 old skylines of interest
a silver R30 sedan with a big nismo sticker on the windscreen and a massive fmic, saw it in sherwood
theres also a yellow c110 4 door in pretty decent nick thats usually around rocklea
and this white c110 2 door that ive seen around a bit in the centenary area. no badges but it has s3 gxe r31 hubcaps sprayed black and some old japanese brand name looking stickers on the front
Just arrived home today with
Model.........MR30, 1984
Type .........Ti Sedan
Engine........L24e, 5 speed manual
Colour........Gold.(once upon a time)
Shes not registered at present, but body, brakes , running gear are all AOK. Needs a tickle in the electrical/ecu dept to get running, then of for RWC and Rego.
This week I hope as I'm for a shoulder recostruction on the 11th. Dec.
I'll let you know how it goes.
Edited by 66yostagea
    • Maybe but doubt it, when I jacked it up it was creaking in the j arm again. The inners are all good, I inspected them. Remember that also it did fix the problem but temporarily.
    • Could be the other bushes. The inners.
    • Once you lose the adjustable bushes, you have almost no adjustment at the front for anything that matters. You can only wind so master caster at the front, and ~7° is fine. You won't have choice of front camber. If you only have rear camber arms (ie, do not also have adjustable upper tension arms), you shouldn't change their length very much, because you will introduce bump steer. And, you will struggle to find a workshop that will be capable of doing all the adjustment work necessary to simultaneously achieve a decent rear camber number, get the toe right, and minimise bump steer. I would guess there's probably 8 hours of work there. So, stockish rear camber is fine. Although, keep in mind, that stock camber, by number value, does not mean stock arm length when the car is lowered. You will need to lengthen the RUCA to get back to stockish values and that will require the tension arm to be lengthened a little also. Without any other guidance, any change made to the RUCA should have the 2/3 of the same change made on the tension arm. But that is only a rough rule of thumb and the relationship might not remain linear across a wide range of adjustments. And it might not also be as close to minimum bump steer as you could achieve if you did the bump steer measurement and adjustment properly.
    • Well it does have a motor with the same DNA as an Accord V6 motor. The J30A is a successor to the Tiger rice cooker C32A motor found in those cars.
    • FD RX7 I would probably marry if legal R32 GTR is toughest NSX looks like it's made from leftover Prelude and Accord bits
