Hey, Matty.
What was the reason for going to the stagea calipers and bigger discs? did the standard DR30 gear suck that badly, or was it just marginal with your power output? I'm considering a stud pattern change to the RX (to suit a proposed S3 rear end) and have access to a pair of DR30 front struts pretty cheap. If the brakes are pretty ordinary (running about 140RWHP atm) then might reconsider whether there's any benefit (running Volvo 4 spots at the front and they work ok)
Also, to fit the Bilsteins, I assume you have grafted new tubes tot he struts. Did you use the Commodore tubes, or have you used something custom? I gather the coilover hardware is bigger than the 2" sleeves that go over Datsun struts.
Cheers
Don't get me wrong - the DR30 stuff is perfectly good. The (main) problem that I had was that I couldn't get enough rear bias with the factory setup. The fronts wanted to lock up and you would spear off the road. The Commodore rears gave me enough rear bias - so much so that it enabled me to put bigger calipers on the front. The pad area of the single piston DR (front) calipers is pretty big - the Stagea stuff is just bigger again. The DR rear pads are tiny things...
I did have a problem with brake fade with the DR stuff, but again, I think it was related to the rear. They would get very hot, the pedal would go "long" and there would be a change in the the bias. That meant that you never had any real confidence in the brakes over any great distance. 15 kms was about where it would really start.
I haven't had any problems with the existing setup. Good pedal even in 40+ km stages - in fact, once they get some heat in them, they just get better.
On tar, you probably wouldn't have the bias issues that I did.
I took it to Wakefield once (on the old brakes) and gave the brakes an absolute smashing. The car pulled up consistently, every single time. Afterwards though, the rear discs were blue and the fronts had cracked...
As for my strut setup, see post #32 in this thread.
Hope this helps! :nyaanyaa:
Thanks Matty - top info :(
Aah now I remember - the Hills Hoist struts :rofl: I remember reading about them.
I think that my suspension dude has some suitable tube left over from when he was contemplating a bid to supply the formula suspension for some series or another. (can't remember which it was - V8 holdens and / or fords IIRC)
I've got a R30 Ti Hatch, '84 model. It's bronze with 135,000 orig kms. Full service history, orig books, I'm the 2nd owner. Four speed auto, (unfortunately). Stock as a rock except for stainless exhaust & turbo muffler, tinted windows & new speakers. Has all the fruit except for a sunroof. has anyone ever retrofitted an original one?
Hey Cam, I had an RMR30Ti like yours since new. Unfortunately it only did 600K before it wore out this year. Bugger. So I got an R30 to replace it. She has only done 380K so is nearly run in. At 135k, yours will last FOREVER.
Cheers and beers. Hugh.
Heyas :banana: Only got ours a couple of months ago and it's currently pretty standard...
YEAR: 9/9 1993
MODEL: R33 GTS-T
BODY TYPE: Coupe
COLOUR: Black
MODS: Sports tuff clutch, and cat back, and 17's that need replacing quickly! :)
Heyas :) Only got ours a couple of months ago and it's currently pretty standard...
YEAR: 9/9 1993
MODEL: R33 GTS-T
BODY TYPE: Coupe
COLOUR: Black
don't take this the wrong way but your R33 is not quite a "classic skyline" yet give it a few more years :P
  • 4 weeks later...
  • 1 month later...
hey all, been a member on here for awhile but not in the classic section..
ive got 4 skylines
year 1983
model dr30 rs
body coupe
colour red
year 1989
model s3 r31 silhoette gts2 no. 183
body sedan
colour red (ofcoarse)
year 1990
model s3 r31 gxe
body wagon
colour burgendy
year 1990
model s3 r31 ti
body sedan
colour stormy glow
jon.
  • 1 month later...
YEAR: 1990
MODEL: R31 Skyline S3 RB30E
BODY TYPE: Sedan
COLOUR: Silver
MODS:
Genie Extractors, 2 inch lukey exhaust
2 inch lowered springs
Silo Interior (well most of it, I'm still missing some little trim bits)
Almost a complete stereo system (MP3 deck, splits, speakers, sub etc) once I finish installing.
I've got to say I don't really call my R31 a classic, not when I sit it next to my zed or my hot rod but hey its all perspective is it not.
And as someone said L series engines never die, they just get noiser.
  • 3 weeks later...
skyline 1988 gts-x
RB25DET NEO
fmic
air filter
3" exhaust
microtech
increased boost
just over 200rwkw tho i have a print out from APC for 243.2 rwkw - which i think they have fudged cuz i dont thinkg its possible with stock turbo and injectors...
car has tein custom coils on 16" x 8.5 watanabe rims -- i love her so much :wub:
  • 3 weeks later...
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
