Hey, Matty.
What was the reason for going to the stagea calipers and bigger discs? did the standard DR30 gear suck that badly, or was it just marginal with your power output? I'm considering a stud pattern change to the RX (to suit a proposed S3 rear end) and have access to a pair of DR30 front struts pretty cheap. If the brakes are pretty ordinary (running about 140RWHP atm) then might reconsider whether there's any benefit (running Volvo 4 spots at the front and they work ok)
Also, to fit the Bilsteins, I assume you have grafted new tubes tot he struts. Did you use the Commodore tubes, or have you used something custom? I gather the coilover hardware is bigger than the 2" sleeves that go over Datsun struts.
Cheers
Don't get me wrong - the DR30 stuff is perfectly good. The (main) problem that I had was that I couldn't get enough rear bias with the factory setup. The fronts wanted to lock up and you would spear off the road. The Commodore rears gave me enough rear bias - so much so that it enabled me to put bigger calipers on the front. The pad area of the single piston DR (front) calipers is pretty big - the Stagea stuff is just bigger again. The DR rear pads are tiny things...
I did have a problem with brake fade with the DR stuff, but again, I think it was related to the rear. They would get very hot, the pedal would go "long" and there would be a change in the the bias. That meant that you never had any real confidence in the brakes over any great distance. 15 kms was about where it would really start.
I haven't had any problems with the existing setup. Good pedal even in 40+ km stages - in fact, once they get some heat in them, they just get better.
On tar, you probably wouldn't have the bias issues that I did.
I took it to Wakefield once (on the old brakes) and gave the brakes an absolute smashing. The car pulled up consistently, every single time. Afterwards though, the rear discs were blue and the fronts had cracked...
As for my strut setup, see post #32 in this thread.
Hope this helps! :nyaanyaa:
Thanks Matty - top info :(
Aah now I remember - the Hills Hoist struts :rofl: I remember reading about them.
I think that my suspension dude has some suitable tube left over from when he was contemplating a bid to supply the formula suspension for some series or another. (can't remember which it was - V8 holdens and / or fords IIRC)
I've got a R30 Ti Hatch, '84 model. It's bronze with 135,000 orig kms. Full service history, orig books, I'm the 2nd owner. Four speed auto, (unfortunately). Stock as a rock except for stainless exhaust & turbo muffler, tinted windows & new speakers. Has all the fruit except for a sunroof. has anyone ever retrofitted an original one?
Hey Cam, I had an RMR30Ti like yours since new. Unfortunately it only did 600K before it wore out this year. Bugger. So I got an R30 to replace it. She has only done 380K so is nearly run in. At 135k, yours will last FOREVER.
Cheers and beers. Hugh.
Heyas :banana: Only got ours a couple of months ago and it's currently pretty standard...
YEAR: 9/9 1993
MODEL: R33 GTS-T
BODY TYPE: Coupe
COLOUR: Black
MODS: Sports tuff clutch, and cat back, and 17's that need replacing quickly! :)
Heyas :) Only got ours a couple of months ago and it's currently pretty standard...
YEAR: 9/9 1993
MODEL: R33 GTS-T
BODY TYPE: Coupe
COLOUR: Black
don't take this the wrong way but your R33 is not quite a "classic skyline" yet give it a few more years :P
  • 4 weeks later...
  • 1 month later...
hey all, been a member on here for awhile but not in the classic section..
ive got 4 skylines
year 1983
model dr30 rs
body coupe
colour red
year 1989
model s3 r31 silhoette gts2 no. 183
body sedan
colour red (ofcoarse)
year 1990
model s3 r31 gxe
body wagon
colour burgendy
year 1990
model s3 r31 ti
body sedan
colour stormy glow
jon.
  • 1 month later...
YEAR: 1990
MODEL: R31 Skyline S3 RB30E
BODY TYPE: Sedan
COLOUR: Silver
MODS:
Genie Extractors, 2 inch lukey exhaust
2 inch lowered springs
Silo Interior (well most of it, I'm still missing some little trim bits)
Almost a complete stereo system (MP3 deck, splits, speakers, sub etc) once I finish installing.
I've got to say I don't really call my R31 a classic, not when I sit it next to my zed or my hot rod but hey its all perspective is it not.
And as someone said L series engines never die, they just get noiser.
  • 3 weeks later...
skyline 1988 gts-x
RB25DET NEO
fmic
air filter
3" exhaust
microtech
increased boost
just over 200rwkw tho i have a print out from APC for 243.2 rwkw - which i think they have fudged cuz i dont thinkg its possible with stock turbo and injectors...
car has tein custom coils on 16" x 8.5 watanabe rims -- i love her so much :wub:
  • 3 weeks later...
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
    • Transplanting the vvt from a 25neo into an rb26?
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
    • Hi Rob It's a nistune ecu. Yes same shop, good reputation. Apparently the computer on the dyno is compensated for temperature.    Chris was saying that the lean or richness of the mixture would be covered in the actual tune, but he's already picking up in advance that it's under what it should be. Regards the dyno, it's also noticeable on the road. But I just want to add something that has just come in, it appears there might be something in the setup of the external wastegate. In the exhaust manifold there is a centre divider between the front three and rear three cylinders. The external wastegate has a pipe from each side that join at the wastegate. Theory is those two pipes just might be pypassing that divider and introducing a problem somehow. Is anyone familiar with the divider in the exhaust manifold and the effects if the two wastegate pipes were to create a bypass path? Thanks for your questions Rob, interested in your thoughts on this external wastegate bypass theory. Regards Rob
