Cheer dude. Yeah it was a bargin, especially because it still had WOF and rego. I'd been looking for a long time tho and the car was pretty rough, if you have a look at the thread on SDU you'll see.
Good luck with your search for one.
BTW, mine owed me $2K nz by the time I got it to it's first trackday.
  • 1 year later...
  • 5 weeks later...
Agree with alot of what you have said, but it is ill advised to tell people not to worry about a cage, as previously stated, safety first. and a molly cage only weighs about 80kg.
Club level motorsport?
Above posts are good, but i would say overkill in some instances
Radiator will be fine if you duct it up and not making stupid power. An NA engine wont stress the cooling system. Im making 230rwkws and mine is fine after realising that the std setup can be improved two fold with some simple guides. Oil cooler would be good, but dont waste the money on a radiator, just use a big thermo in the std shroud. Even thats only for redusign agro on the engien with the clutch fan...not froma coolign perspective
Rip the weight out of it, and R33 GTS25t brakes all round will be fine with only 1100kg to stop. Its tyres and suspension that stop the car quickly and help with consistant lap times. Big dollar brakes look horn but do little for lap times if your susp and tyres are on the money.
Seat would be good, so would a cage. But dont go overboard with the cage as the std body is pretty floppy and jsut worry about safety. The weight of the cage to get the chassis stiffened would be expensive and beyond what a club car needs
Just had my car resprayed and more then ever looking at a 4k shitter GTSt to play with rather then my road car. I already have a sensible but dreamy GTSt track car budgeted out. An 1100kg + driver GTSt with about 200rwkws in a sorted chassis would be quick, fun, cheap and reliable :thumbsup:
Good luck with it...ifs a club car go crazy with the weight side of things, but keep most of things as per Nissan and spend all your money having a ball in it :)
  • 3 months later...
I am about to build a new R33 GTS-T for circuit use only. A loit more serious than i have in the past and will include complete strip out, Breg, comprehensive cage etc.
In the past (2003) i won my class (over 4,000cc road reg) in the WA Speed Event series in a R33 GTS-T. 9 trophies for 9 events in 2003 and some others that we collected along the way.
This was my daily driver road car as well.
All we did was put in a fire extinguisher, harness (only for the Track), king springs and bilstein shocks 25mm lower front and 28mm lower rear.
increased boost to 13psi (note standard intercooler used), K&N filter, sticky bridgestone tyres on standard rims, un plugged HICAS on track days.
This car was dynoed at 297hp at rear wheels and was not the fastest, but often featured in the top 15 outright and embarressed $80k V8's.
One thing we did find out much later with this car was that it had a R33 GTR standard computer in place of the GTS-t one. We have wondered with out proof or research if this helped improved performance!!!
Forgot to add that we also had a turbo back custom 3" exhaust with hi flow cat.
Edited by racegtst
Its worse than that....you've only bought the first set of tyres....1,500-2,500 a set it really adds up.
On the race car I get through about a set every year (2 years with the number of rounds I miss lol). But I race people who run new tyres every race meet.....1500 a weekend * say 8 meets a year. Ouch.
makes go-karting seem so affordable, $240 sees two full meetings.
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
