Which would you go for???ive got 2 options....
1) get splitfires, and hope that gapping at .8mm will work
2) regap my .8mm ngk's to .65mm, and hope it doesnt missanymore
either way will i lose a noticeable amount of power gapping from 0.8mm to 0.65mm????ive heard that too low a gap will slow the car down heaps???
https://www.sau.com.au/forums/topic/138228-8mm-gap-vs-65mm-gap/
As rev210 mentioned, it really depends on your power/boost and revs the problem is occuring at...
Assuming it's the usual Skyline misfire, my experience is that gapping the plugs down only somewhat resolves the issue in that it no longer misfires, but instead you get a lovely flat spot!
I bit the bullet and bought Splitfires, installed new plugs at 1.1mm gap...worked perfectly on my old R32 that was running 1.1bar at approx 170rwkw...No misses ever again, the car was incredibly smooth through the rev range and I did alot of k's with that setup...in fact, same story with my SII R33...
Gapping the plugs just masks the actual problem, which is a weakness in the ignition system...usually the coil-packs (cracked or compromised in some way).
Funny this exact issue has been going thru my head the last week.
I put the plugs in gapped at 0.66mm from the word go without ever running 0.8mm. Is it worth pulling them out, opening up the gap and checking to see if the spark blows out?
Brent.
If you are still running the stock turbo etc. then 0.8mm ought to work well enough all things being healthy.
get NGK BCPR6ES or BCPR6ES-11's , if you haven't already and gap them down to 0.8mm initially. These are copper plugs.
When gapping the plugs do not press the gap closed with the feeler gauge still in the plug gap like I have seen some young-un's do.
Have a good look over the coils for any hairline cracks or discolouration. I had an issue with one once and as a fix used generous amounts of high temp epoxy , it might be a temp fix depending on the extent of the cracks.
With the coil cover off you may be able to confirm an issue if in the dark you have a good look to see if there is any arcing.
They do get very hot under that cover and I wonder if nissan may have given them a snick too much dwell time for longevity. The extra dwell would help emmissions I'd imagine but does increase the heat at the same time and possibly reduces the coils lifespan.
no you wont lose power. i have splitfires, and tried larger gaps, even 0.8 i got a few misses here and there, 0.7 works for me.
do the checks as mentioned.. i fixed a coilpack once with a tiny piece of electrical tape.
thanks heaps guys for the advise, i think im going to just go and buy some splitfires....i regapped my plugs to .66mm,and i still get the missing occasionally, but what is worst, my car has a huge flat spot which wasnt there beforehand, this is running 10psi
Is it true 1.1gap will be fine with splitfires or should i just buy pregapped .8mm ngks asadvised.
thanks alot guys
    • I do have their “Nissanie Motorsports Co.” vin plates, but I am curious if anyone would have more info on them. Like how many cars they’ve imported and whatnot
    • Been a long while since i have updated this money pit lol.  Have had a few tune related issues with the car, first blowing the frost plug out the back of the head and then blowing the headgasket 3 months later, which has now been retuned and sorted. Done a few little changes along the way as well, i wasn't happy with the wheel and brake setup, so start of last year i managed to get myself a set of r35 brakes and nismo lmgt4 18x10.5 +15 Upgraded to now running a Precision Gen 2 6870 with a 1.15ar, to be honest felt more like a downgrade as the car feels much lazier around town compared to the Gen2 6466 previously. 0761719E-5683-43F7-BD3B-4BD94335DFF4.mov
    • Hi there, i am currently using the Elmers Racing Billet merge collector, we are using sch40 tubing and 1.5" ID, no cracks so far. however if i was to do it again, i would go sch10 with 1.25" runners
    • I haven't touched the turbos so might need to look at that 👍 Appreciated 🙏
    • If you haven't replaced the OEM turbos, replace them sooner than later. I have seen recent pictures of what OEM ceramic turbo failure can do in an RB26 and it will make a 10k AUD budget look like a joke. Single vs twins have been done to death on this forum. If your turbos haven't fallen apart you can probably send yours off to Hypergear for rebuild. The journal bearing option will have more turbo lag but it's a good bit cheaper. I would probably go for ball bearing CHRA but keep in mind ball bearing turbos are more particular about oil pressure/flow.
