hey guys, jus wondering if anyone could give me some info on putting an rb26det into a r33 gts-t? is there alot of modifying to fit the engine? also i imagine this is an expensive thing to do?
very expensive... being that i wouldnt run the risk of using stocker turbos.
So its a 5 figure adventure.
Whats your power goal? and how much do you want to spend? For 250-300rwkw, keep the RB25, do some internal work for anything over 280rwkw (rough rule of thumb). 250 - 270 is a good figure to aim for with a 25 as you can achieve that power with little more lag than stock, and keep the internals stock. Any more than this and your up for some big dollars
If you want morepower and little lag go for a RB30DET exelent base for 300 - 400rwkw less stuffing around than a RB26 and less lag.
my 2 cents
cheers
You can only use one engine mount the left one needs to be modified to clear the turbos and associated parts. Standard RB25 box fits. Sump needs to be modified.
Drive in drive out works out to be in the 10-14g range. Ive priced it all before....
Its pretty straight forward, RB25 box will bolt directly onto the motor, you can use the rb25 loom to run the thing, IF, you convert to a single turbo setup, <much wiser move IMHO, properly selected single eg, gt30 with a .64/82 rear will be on boost earlier most likely than the stock twins> if you stick with twins you'll need to get the loom from the 26 wited in to suit, as you will need to retain the dual AFM's and o2 sensors etc..
i used stock r33 mounts to the motor with nismo mounts to the subframe, and box..
as for the sump theres a couple of optiosn you can do.. use an rb25/30/20 style sump, you'll need to bash the side where the oil pick up is, and prevent it from leaking, <slightly dodgy method> or modify the gt-r sump, by chopping off the diff housing, and cleaning it up, then welding up the holes left from where the diff passes through it, that'll fit in perfectly and clear everything..
you can also get some extended units from various places, ive had one developed for me locally by a mate of mine, will hold about 10 litres of oil, and pretty crucial if your going to be belting it on the track, if its just a streeter you will be fine with the modified stock sump..
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
