they only run partially at idle to stop flowing at the full rate when its not needed.
how did it go fitting in the 33gts-t?
does the whole assembly slide in or did u just have the pump and fit it onto the gts-t standard bracket?
I just had the pump, i didnt install it. From what i gather the mechanic that installed it just used the standard bracket.
If you dont like loud pumps i reccomend giving a 34 gtr pump a miss, i may replace it with something else in the near future!
thanks for that.
i have the whole r34 gtr assembly, the pump comes with a thick rubber surround, im pretty sure that would keep it quiet. if he fitted it to the stock bracket chances are its metal on metal to make it fit in a near standard position.
i have a bosch pump which is touching the bottom of the tank, but i installed it with rubber everywhere ie no metal on metal, and its only just louder than stock, not noticeable unless u are really listening to it.
  • 6 months later...
Ive just installed a GTR pump. Quite noisy but then again I only have about 10L of fuel in the tank. Can hear it wirring away. Might take it out one day and put some rubber around the pump in between the hose clamp.
I was worried the pump might be on the way out but it seems that a few people seem to find them noisy.
I tried to keep it from resting on the tank but it was pretty tight in the R33gtst. Its a sedan so I'm not sure if the tank is a different shape.
Anybody pulled them out to put rubber in there and found it reduces the noise?
Thanks
Buzzing - depending on how loud it is - 1 person's loud is another person's quite.
Either nitrile rubber or EFI hose.
You can buy big EFI hose and slit it. Cheapest nitrile rubber (never had a problem with it decomposing) is buying a pair of nitrile rubber gloves from supercheap auto. About $10. I just cut them up and use that.
I still say no rubber is required. I dont' have rubber, my pump sounds the same as any gtr pump in a gtr.
The only time i've ever used rubber is when i was doing something special. not just a normal hose clamped pump install.
Nah, I'm pretty sure the rubber is different. Radiator hose is water only.
Cheapest option (won't cost ya anything) is to grab some of that hose that came iwth the cradle, slit that, and put it in.
Have you put that extra clamp in yet?
Have you put in a new tank seal yet?
    • find it funny everyone claims different fuel chains, do different things with their fuel blah blah blah. We don't have that many fuel terminals in Australia. The fuel tanker trucks drive into the terminal, fill up, and drive directly to the service station and dump out. The majority of fuel you get, is coming out of the same terminals. The variation is actually at the individual service stations and how good their tanks are, as well as how much turn over they actually have. Older fuel stations, that haven't had their tanks replaced are going to end up with the worst fuel. Also a lot of older stations have shit design, and shit maintenance, and end up with more water absorption into the tank. This is when you then get a bad batch of fuel. Other shit things happen, like tanker drivers have a f**k up, and starting to unload the wrong compartment on their truck into the wrong tank.
    • This one?? In other news: I cannot tell the difference between my red MX5 with the silver grey hard top......... and the Ferrari 599XX EVO, they might as well be twins, well.......apart from the big wang hanging off the back of the Ferrari...🤔🤣, without the wing they are identical
    • Turn it into the pride flag
    • I think you'll find we're confused about what you were trying to do and how you were doing it. I would have thought that block rigidity was something you measured while loading the block in beam or in torsion, and that you would do so before and after grout filling, to see if putting material in there created a "composite" construction with the expected rigidity increase. Notwithstanding that the true function of grout is less about gross rigidity than local (ie preventing bore deflection/splitting and tying the bores to the main bearing locations a little better, etc etc). It is nearly impossible to follow your description of what you've done without closing ones eyes and making "aliens" hand shapes in front of oneself to try to follow the manipulations you've made. It's still unclear to me what you were trying to prove.
