Hey everyone.. Ive recently purchased a 1997 series 2 r33 GTS... And when i bought it i was in the understanding that it had stock suspension.. but after close inspection of the car it has NISMO motorsports suspsension on it.. Is this stock with all skylines? Or just the GTS's? And another thing.. I was sure that ALL skylines came out with HICAS.. But my nissan fast results tell me i have IRS? Any comments would be great thankyou..
https://www.sau.com.au/forums/topic/138262-gts-suspension/
nismo suspension isnt standard.
irs stands for independent rear suspension - what this means that each of the rear wheels is independently sprung, as opposed to a rear axled car.
hicas refers the the four wheel steer movement of the rear wheels, the simplest way to check if you have hicas is to turn your car keys into the acc position and check your dash for a hicas light.
you can even feel the rear end turn its wheels when you go around a round-about, it tends to feel slightly drifty. most people lock the hicas as it tends to make the rear end unpredictable for track use.
https://www.sau.com.au/forums/topic/138262-gts-suspension/#findComment-2575005
nice find if its come with nismo tuned suspension
if ur willing to jack the rear up u will see (if uve got hicas) a big solenoid thingo in front of the diff (ie blocking the diff from ur view) and coming from that are some arms with boots on the ends of them (black rubber things to stop dust and dirt getting in) that go towards the wheels.
if u see that then uve got hicas - it controls the rear toe arms to essentially turn the rear wheels in accordance with the speed ur going to make the turn 'easier'
https://www.sau.com.au/forums/topic/138262-gts-suspension/#findComment-2575141
Hey thanks guys..
Obviously nissan fast was wrong because i have hicas :P
Found it in the dash AND there was a fuse for the hicas in the fusebox...
Maybe the last owners put the nismo suspension on it? Im the first owner in the country so... the whole car is a foot off the air as well... Which made me think that it was stock
4X4 spec
https://www.sau.com.au/forums/topic/138262-gts-suspension/#findComment-2577756
Well it turns out i was wrong.
There is A. No hicas light. And B. nothing that remotely looked like hicas under my car :S
I actually have no idea. Ill post some pictures of my diff and suspension and let you guys be the judge.
Just got back from looking over the car.. In my fuse box in the boot there is a fuse for hicas but im not sure if the box they made to cover the box is a standard for all skylines or just for GTS's... And i also found a weird box with heaps of wires comming out of it lol. Pics attached.
Edited by OBNXSH
https://www.sau.com.au/forums/topic/138262-gts-suspension/#findComment-2581242
this is what a hicas lock bar looks like
in its place should be a big solenoid thingo
the rubber boots are connected to the toe arms that turn the rear wheels
(PS this is the first decent pic i found, i'll try and find more)
which is from this car by the way which is MAD: http://www.cardomain.com/ride/447636
Edited by usherly
https://www.sau.com.au/forums/topic/138262-gts-suspension/#findComment-2581417
thought you said you had a hicas ecu and a light on the dash?
from the photos no hicas there... congratulations you just saved yourself $150.
I overlooked it... It said ABS lol dont ask me how i got HICAS from abs but i just did... The one thing that puzzles me is on my fusebox in the boot it says HICAS as the 2nd fuse from the bottom... Maybe its just the universal cover they make for all fusbox's on r33's. I suppose not having it is a good thing.. Most people dont like it? Also what did i save $150 for. lol sorry.
https://www.sau.com.au/forums/topic/138262-gts-suspension/#findComment-2581449
no idea how u mixed them up.
like i said in my pm to you, most skylines would probably just share parts between for all the various options in skylines.
well no most people don't like hicas, its ok for street use, makes turning a breeze, but for track work it makes the rear end unsteady and unpredictable... you saved $150 for a hicas lock bar (elminates hicas on hicas enabled skylines) - that silver thing in usherly's post.
https://www.sau.com.au/forums/topic/138262-gts-suspension/#findComment-2581468
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
