I am planning to change the gear oil in my R33 GTS-T. I have already purchased the 1 gallon lightweight redline oil.
I have an empty 1 litre VMX80 bottle that has a little hose attach to the cap. Can I use this bottle to fill up my gear box without a pump? (some people mentioned to use a pump to fill it up)
https://www.sau.com.au/forums/topic/13827-change-the-gear-oil-without-a-pump/
  • 4 months later...
Not sure to tell you the truth. I haven't ever tried it this way.
I managed to get a 1/2 inch torque rench to the filler and drain plug. Gave me heaps of leaverage to get the nuts loose. I still almost spat my guts out my bum cause the nuts were so damn tight though !!!
I 'think' you'd have to take the gearstick surround off, then the 4 bolts around the gearstick. Then that might open up the hole which may let you get a hose down there and put it in the filler hole. Then just use a funnel thingy to fill it up.
Just don't spill the oil inside the car !!
J
I think someone was saying that you can fill it up via the speedo cable plug if you can't get the filler nut out.
Just undo the speedo cable and pull it out, then do it that way.
Not sure if you'd be able to fill it up from inside the car if you use the speedo cable way though...
J
guys, the best way to fill it up is : after u drain it from the bottom plug put that plug back then take the filler -level plug out on side of the b/box and use a pump to fill it up ( i use compressed air to pump it up there ). if u want to get to it from the top this is how the gear stick comes out .
take the trim mould off , gearknob off , boot off , ( u need new cable tie to put back )then there is a c-clip that u have to take off ( u need a long nose to sqeeze it )once u take that off the gear stick just comes out .
warning here though u won't know when its full unless the filler -level pug is out but even then if u fill from there i'm not sure that it will go in to the box on gtrs 4wd 's it won't, it will end up in the trasfer case .
don't bother doing it this way besides u should be able to take the plug out so u can check the level everytime u do a service so u must be able to take the plug out .
u need a long wrentch ( like 300 mm ) with a 1/2 inch drive ( or maybe 3/8 cant remember ) its shouldn't be that tight i never have any trouble undoing it .
Read the link
I did this on two cars on friday, one through a stupid little hole and one through the speedo sender.
USE the speedo sender hole instead of the normal filler hole if u cant get it undone like me :) its a hell of a lot easier, and you get the correct level too.
hmm not the same gearbox, but last week i changed clutch and gbox oil in my other car, damn filler plug was rounded off and so damn tight, the only way i got it off was to take the whole box off and weld a long bar to it to break the seal. total pain in the arse!
as for filling it without a pump, get a length of hose (about 3 meters) that is big enough to fit in the filler plug hole but so its loose. and get a funnel. stick these two together by what ever means neccesary.. silver tape works good to seal it.
put one end in the filler hole and the funnel end above the car (may have to attach it to something unless you feel like holding it there) then through gravity the oil will flow down into the box slowly. if you know how much to put in fine just put that in, but if not just keep topping it up untill it runs out the filler hole and then let it drain till it stops then replace plug
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
