dont think you Gold coasters are that "SPECIAL" theres a Dan Murphy's at Woolongabba :(
"cheapest piss anywhere guarantee'd"
Oh I didn't mean it was the only Dan Murphy's around... I just didnt know if other branches had the same prices or it was just that particular one... all I know is I refuse to buy alcohol anywhere else coz Uncle Dan is the MAN!
EDIT* This is Anna (impact_blue) incase you were a little suss on the slight homo responses :ninja:
van gough vodka is the one with his painting's in the bottl and u can see it through the glass!
:P:ninja: someone else knows what i'm on about.
do u drink it straight?
Actually, the flavoured ones are INCREDIBLE straight. If you're a vodka fan, you must try the wild apple on the rocks. mmmmm... it's perfect!
havent been back to work yet, ill let u guys know ASAP.
Thanks heaps mate! I am struggling no-end to get it in Qld (off the shelf, ofcourse, it can be ordered online no worries)...
    • Ok, can confirm.  if you use it like a normal human being in the real world, it works fine.  it only starts crossing wires if I keep using the fob over and over again in a very short period. So if I just chill the f**k out, it works 😂😂
    • Im about to run a e30 mix of e85 and 98ron but i read that australian fuels specifically 98ron doesnt contain ethanol so on the calculator when it says pump ethanol percentage do i just put 0 or is this statement even true? And if it is true i assume i dont need to test any 98ron pumps.
    • So... the fob I had for my Skyline always had this issue where the "Unlock" button worked with no issues but the "Lock" button did nothing (and I always had to lock with the key) I thought I'd try resetting and pairing the key to the car today to see if that fixes the issue. I did the standard steps to program a key but realised my central locking was doing its own thing from time to time. 1st time: The driver-side doors would not lock or unlock when using the fob. No issues with the key. I figured it was the right time to change the battery in the fob so decided to go get one. When I went to the shop all doors locked and unlocked with the fob (while it had the old battery 🙃)   2nd time: When I locked the car, it would lock itself and immediately unlock. If I unlocked it, it would unlock and immediately lock.   3rd time:  After a bit of cursing and praying, that weird bug stopped. But then the rear passenger door started being a pain. It wouldn't really follow what the fob was asking it to do. Sometimes even using the key would not do what I wanted. So I'd lock the car with the key and all doors would lock, but the rear passenger lock didn't do anything at all. And then after a few moments, it would work again.   Is there a fuse that I should be looking at? or, is this one of those things where the door card needs to come off and some unit needs to be replaced? It just seems to happen from time to time and if I give her some space and come back later, there are no issues  🤦‍♂️ Also, should I try to program the fob again to the car just to see if that solves it?
    • One would assume a turbo is somewhere in its future down the line given they slap turbos on pretty much everything that arrives
    • I’m guess it’ll end up with a turbo
