I am just thinking that my clutch has some problem. Everytime when I change gears, I will depress the clutch pedal all the way down. But, I only need to release it a little bit and the clutch start to engage.(car start to move)
And I found that the clutch fluid level is in the middle of the "max" and "min" mark. Should I put more clutch fluid in it? And what sort of fluid should I use to top up? Can it mix with different brands?
Or should I change all the fluid? if so, how to do it?
Thanks! :)
https://www.sau.com.au/forums/topic/13832-clutch-problem/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
