Got My Car Back
not2.5 r33
 Share
hey guys got my car back from all star tuning systems today i got a new tune put in it made 197kw on .6bar boost and im pretty impressed with it but can some one tell me how much hp and psi that is coz i dont totally understand bar of boost thanks guys
Edited...
Should have paid more attention... :(
Well now you have a figure, its time for you to start adding to it before the next SAU dyno day in Jan 07...
Think of it as a challange or in my mind an excuss to spend more money on you car... :rant:
yea rb30 block rb 25 head the guy who i bought it off had dyno papers for 480hp atw but turned the boost down befor i bought it for reliability and theres no way i need that much for road use but its good knowing its possible
yeah i saw your car mate...black one isn't it? i'm always at allstar tuning
thats a good figure for low boost.. you gonna throw some more boost into it?
i was just thinking 197rkw seems alot out of 8.5psi. Was the rb30 built from scratch or is it all just stock internals?
stock internals from the Rb30 can handle a hell of alot.
'a mysterious dusty old man who emerged from the bush once said, "they are bullet proof ", i didnt take much notice cause he had a stick with a checkerd bag hanging from it. So I told him "You needs a shower mate". and he dissapeared into a puff of smoke, although he left his thong on the ground. I was missing my left shoe so i decided to use his.
hahahah!
 Share
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
