I got my car fitted with an apexi power fc and dyno tuned yesterday. When i went to pick it up the guy said that as soon as they put the apexi computer in this orange light in the top right corner of the dash came on. I aint sure what it is as i have no manual with the car cause its from japan. Its an orange picture with the word check through it. The car runs perfect and the guy said its something to do with the computer and the car not registering that item but it wont effect the car. His trying to find out about it cause he said its happened to the other skylines he's fitted apexi power fc too aswell, just wonder if anyone here has had, seen or heard of that happenin before and what the person done to get rid of that light. It aint effecting the car so i dont care that much but just dont want the light on the dash.
https://www.sau.com.au/forums/topic/138378-help-orange-light-on-dash/
change mechanics. obviously doesnt know wat his doing. if his TRYING to find out and saying its SOMETHING to do with so and so.
check light (correct if im wrong) would be detonation/pinging? as the power fc uses those lights as its warning sign.
Have you checked the fuses? Check the fuses to see if no fuses are blown. The fuse box underneath the steering coloumn.
The PFC is quite sensitive to blown fuses etc..
Yea you are right if the engine light goes on when the car is running and operational.. means that one of the sensors are hitting its max value. Either pinging, afm, injectors and something else.
Have a read of the Apexi FAQ -> http://paulr33.skylinesaustralia.com/docs/...powerfc-faq.htm Awesome info!
Why does my engine light flash when I drive with the PowerFC?
The PowerFC uses the factory engine warning light to alert the user of "upper limit" or ceiling values in the engine systems. Things such as airflow meter max value, injector max duty, excessive knock will cause the engine warning to flash. Usually the engine flash is in a sequence of 3 flashes each 0.5 seconds apart. Should you experience this you should review the hand controller max values (press down when in monitor mode and displaying values to see the max values for each) and consult your tuner immediately. Excessively high knock can cause engine damage. Running on max injector duty can also be fatal so speak to your tuner. Aggressive tunes that are tuned around winter temps/airflow and being run hard in summer may cause these symptoms if the tune is very aggressive and on border line of maxing out the stock components. This is only hearsay but I have seen this from at least one or two members.
See Basic Hand Controller functions and use for information on how to isolate which warning is triggering the engine flash light
It was the place where i got it dyno tuned... that installed it. This is a pic of the light
Cars fine yeah, boosts 14 pound and awesome. He said it came on as soon as he plugged the apexi power fc in. Its a straight plug in. That light woulda came on for anyone
14PSI on stock turbo? WOW :teehee:
Check fuses me thinks
well 13.9 boost is the highest it was at on the dyno but went to 14.1 that night cause it was cooler, 8 and 10 are the other boost settings.
I've heard everywhere 14 pound is fine on a stock turbo, not much higher though
Which fuses under the dash, engine bay?
Edited by series2r33
i got a e-boost 1 and its definatly on, lighting up and showing boost increase and stuff
errr.. The PowerFC Boost Controller Kit needs to be turned off if you are not using it.
The FAQ has all this info.
If you are not using the PowerFC boost controller kit make sure you disable this feature. Go to the "Etc" menu and choose "Function Select" and then choose "Boost Control Kit" and set the option to a Japanese character that looks like a plus sign. This will disable the PowerFC boost controller kit
Take it easy hey lol
Thanks heaps i rang up the guy and told him what u said bout the power fc's boost controller kit being left on and he said yeah but its not using that boost controller and i said yeah but is it still switched on cause u guys on the net reckon thats that'll be the reason the light is on. And he said yeah it might still be on, so im goin in there tomorrow and his gonna switch it of if its on.
Nothin is gonna happen meanwhile hey? just an orange light doin f**k all...
Im gettin him to do it cause i dont no how to do it myself as im new to using the power fc and the book that came with it is all in japanese.
$980 and a jap book or $1600 and an english book, I'll keep my $620 bucks thanks. no books worth that much lol
go here
select documents
click on the power FC FAQ
scroll down and it will show you, good idea to get to know whats running your car.
this is the menu you change it in
Also there are sites hosting the pfc manual, there must be, I got mine that way.....just can't remember where?
http://www.apexi-usa.com ?
http://www.apexi-usa.com/pdfInstallation/13.pdf
Edit: Wait the above is only install manual. What Chris said Paul's site would have it all. http://paulr33.skylinesaustralia.com/
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
