My car has a protective layer of grime.
hahah yes that's what it was going to be about... how the heat dried the dirt, which turned into fine dirt. and the wind took it like so. but then i decided it was a boring subject. except i pressed post instead of otherwise.
https://www.sau.com.au/forums/topic/138381-weather/#findComment-2577275
nah only had car window down while it was idling away.
however, here in my room, all my stuff has a new dirty texture to it having had the window down, even with a flyscreen :teehee:
the cat just walked inside and he's a lighter shade of gray
https://www.sau.com.au/forums/topic/138381-weather/#findComment-2577324
Miserable one day...shithouse the next
will soon be replaced permanently with
Beautiful one day - Perfect the next
sif the worlds most liveable city
Melbourne is a hole.
come on man melb isnt that bad i think it is the most livable city in the world :teehee:
Edited by assyrian4evaa
https://www.sau.com.au/forums/topic/138381-weather/#findComment-2577395
HAHAHA
Geoff you forgot to mention the next part of the QLD weather thats never spoken about where it is hot as all shit and pisses down with rain for a good week :teehee:
https://www.sau.com.au/forums/topic/138381-weather/#findComment-2577622
how hot was it today!! then picture me in a mechanic workshop doing a diff in a ba xr6 ute on the freaking floor with dirt and oil all over me!! it reached over 40deg in the workshop.
are u purposely being erotic?
:P
https://www.sau.com.au/forums/topic/138381-weather/#findComment-2578127
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
