  • 1 month later...
  • 5 weeks later...
HEY GUYS I'VE GOT A R31 PAINTED S15 PEWTER OR SO IM TOLD... ANYCHANCE OF GETTING THIS PAINT CODE SO I CAN GET MY GRILL AN LIP PAINTED UP :)
what paint codes would a white r32 gtst type m 93 be?? theres four whites to choose from.
Easiest way for both of you is to go to a car yard with a pewter S15/white gtst for sale, open the bonnet, have a look on the build plate, paint code will be there.
  • 3 weeks later...
I looked everywhere all over my car, including the build plate, and i cant find the paint code anywhere. I even got the painter that im going to to have a look, but he couldnt find it either, its either just not on there or its in fricken japanese. How can i find out my paint code?
  • 4 weeks later...
  • 4 weeks later...
  • 3 weeks later...
Hey i have a 1997 R33 GTR series 3.. it is white... can anyone help with the paint code
thanks..
I just got some touch-up paint made at AutoOne - Code QM1-Polar White. Unfortunately it doesn't match. It is a bit whiter than my GTR ('95 Series 1) - is a little bit "bluer".
Fortunately I was doing some testing before it put any touch up on any scratches or anything.
Anybody know how to get the correct QM1? The guy at AutoOne said there's a couple that are all a bit different. (due to local market having Nissan QM1 white different to the Japanese market one).
  • 1 month later...
My 33 has KN6 K on the build plate. It seems there are two different colours with the same number, KN6 pre 95 is dark grey where as KN6 K (Kouki possibly) is Purple/blue dark grey. Thought this may help someone out.
  • 3 months later...
  • 1 month later...
  • 1 month later...
  • 2 months later...
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
