  • 1 month later...
  • 1 month later...
  • 3 weeks later...
  • 1 month later...
Can anyone recomend some where to get touch up paint for a Nissan Stagea NM35 with paint code "KYO"?
Tried Repco and they had no idea.
Cheers
Andy
Have the same question... for any jap imported car. People at Aussie car stores have no idea... some idiots never even heard of nissan skyline before.
I doubt panel beater can make up a can of touch-up paint.
  • 3 weeks later...
  • 1 month later...
  • 1 month later...
  • 4 weeks later...
  • 1 month later...
so when a panel shop/bodyworks repair a car what do they do for paint? 99.9% of panel shops have a paint system to which they can mix any colour they have a code/formulation for, and if they wont do it for the general public, which most wont, they will direct u to the local distributor which they buy there paints from, which will be able to mix and sell ur colour at request.
hey guys ive got a maroon 33 gtr any idea of that code???
take note of a few posts up where a fella has posted the picture of his plates and the next person has replied to the post with the code, refer with that code(believe it was 732?) back to the picture to see where it came from and voila, thats where ur code will be, its in the same place on 99% of all imported nissans.
I have a r33 1995, its colour is Polar White - QM1 but on page 1, I read that QM1 is not for skylines :|
yes qm1 is an r33 colour for skylines, it also exist on pulsars, x-trails and several other nissans, you can always believe write ups like that on the net, the code on the vehicle is the only one to believe.
what would the paint code be for the greyish colour which is painted on the bottom of R32 GTR front bar lips?
dont believe they ever kept a record of the grey but i may be wrong, best way to find out is to take ur vehicle into a car paint shop and they may check the code in there system, depending on there system it may come up with a bumper colour(dupont is a ripper for it).
Anyone know who can get the original Nissan paints from Japan, chasing MNPII for R34 GTR as we need it for a customer. If so, please pm me.
impossible, ud have to call nissan in japan, and if they spoke english they'd tell u what im about to tell u, grab/find the paintcode for the colour u want, go into a local car paint shop and quote that code and they will be able to mix the colour for u.
its 99% impossible to use the exact same brand of paint that nissan use on there vehicles, thats if they are like most other manifacturers, which put out tenders to paint companys i.e dupont, standox, glasurit, spies hecker, etc etc, saying they want 2000 litres of kh2 silver(or whatever it may be) the paint companies will come back with quotes, most of the time lowest quote wins, say it may be dupont, then the manifacturer will go and use the 2000 litres then bang, they need more paint, so they will do the same tenders, although this time another company might come up with a better price on the same colour, so the next 2000 litres may be done by spies hecker. this also be the reason for colour variations in cars, u and ur mate might have the same car with the same code, but swap doors of the cars and they might stand out like a sore thumb, because the paint was made by different paint companies, and say the 2nd company may not have made it as good as the first.
Anyone found paint codes for the RB26 rockers covers
codes for rocker covers and wheels and other removeable parts were never kept, take it to ur local paint shop and give them some time and they should be able to match something up for u.
hope this answers everyones questions about paints etc. as i work in one of these 'car paint shops' i get snowed upon with similar questions on a daily basis.
  • 3 weeks later...
Hey guys ;)
98 Silver
hi, thought of askin help frm u abt my v35 color.
i had an accident last week n need a paint job on my rear bumper. mine is 04 v35 skyline n my dealer said its pearl white. is it QT1 or QX1?
n is it alrite if i tel da smash repair guys dat code n it b alrite?
thx alot.
vic
    • It's (the TPS) buzzing? Or something else is buzzing in response? Remove the IACV from the plenum. Block the hole into the plenum with your hand. Get someone to start the car. Let some air is. Do the revs flare up? This is checking that the path into the plenum is clean. After that, is the air hose leading to the IACV fuly clear? After that, either you didn't clean it thoroughly enough to allow the valve to move, or it is broken.
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
