stock skyline r34 manual ecu
airbox + snorkle (SOLD)
brand new NKG coppers
used briefly NKG iridium plugs
stock side indicators
3" stainless steel flex pipe brand new unused
nissan badge
gtt rear badge
touch up paint for bayside blue r34 and white r33
long cover thing that sits on engine over coils/plugs for GTT
little metal things that you put in xenon headlights to convert to halogen.
want to sell as a lot, willing to let it go cheaply.
first reasonable offer gets the lot.
Items located in perth, would rather pickup.
Edited by noise
https://www.sau.com.au/forums/topic/138432-r34-gtt-parts-want-them-all-gone/
ok few people pulled out of items so they are still for sale.
one guy at least explained he didnt have the cash, the other guy just ignored me after saying he had made payment but really hadnt.
rude as!
Edited by noise
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
