Well, its on again, the Bathurst Speed Weekend.
On the Saturday is a supersprint - standing start near the top of conrod right down thru the chase finishing at the main finish line.
Sunday is even better, a hillclimb up the track from conrod right up to macphillamy park.
$115 for each day, very cheap! And a good opportunity for a beer or 3 on sat night.
All you need is long clothing, AS approved helmet, fire extinguisher and battery triangle (and 2nd bonnet restraint if your car is pre 83)
Supersprint Supp Regs: http://www.blcc.com.au/dmdocuments/supersp...%20suppregs.pdf
Hillclimb Supp Regs: http://www.blcc.com.au/dmdocuments/hillclimb%20suppregs.pdf
Supersprint Entry Form: http://www.blcc.com.au/dmdocuments/ssprint...ntry%20form.pdf
Hillclimb Entry Form: http://www.blcc.com.au/dmdocuments/hclimb%20entry%20form.pdf
With a bit of luck this will be hge32r's return to competition....how else is interested in entering or just coming along for a weekend away?
https://www.sau.com.au/forums/topic/138446-bathurst-weekend-2-and-3-december/
  • Replies 86
sorry if semi-offtopic, isnt there a full track day in december @ bathurst aswell? or is this it?
no cams or club member to go into this??
im only really into the hill climb.. how many attempts/practice sessions do u think u'd get.
Edited by illusiVe
aww shit
my old car
boys, this truly is a top event
the supersprint starting on conrod is tops
and as for the hillclimb, you get to do a "tyre warming exercise" (no shit, thats what they officially call it) beforehand./ so smoko the tyres
get entered
duncan, pls keep me informed of this event. id like to come watch on sunday. cheers, mark
Sounds good. I guess we should start organising accomodation now.
Minimum 4 runs, max 100 entries on day one, minimum 3 runs, max 80 entries on day 2.
I certainly hope we get more than 3 runs in one day. That would suck arse to go all that way for 7 runs over 2 days.
Yeah i was reading that... it seems a little harsh :)
I guess though.. 100 vehicles is a fair number, but still, so little runs as a minimum is suprising. Hopefully they dont get so many entrants!
no such thing as "track days" at bathurst using the whole track. unless you are racing a race car, built to a class you have no hope of driving the full track under closed 'race' conditions. :(
(Well, for watching unless someone donates a car)
finish your own car you butt pirate! this is 2 months away. stop bludging and get crackin'. gives you something to aim for. :(
finish your own car you butt pirate! this is 2 months away. stop bludging and get crackin'. gives you something to aim for. :D
You know what ive been doing this afternoon?
Shopping :dry:
There's just too much to consider, its getting to be a giant headache
Still, ill be driving up in one of the cars either way, so yeah, pub on Saturday night sounds good
You know the worst part about this? I was having those CV joint problems when this was on last year, and only the week before i magaed to get it all finished/fixed, so i missed out :P Still, the observant ones wouldve noticed it parked up there on top of the hill :P
Ya gotta love a race car driver that doesn't read the sup regs!!!. Sunday's hillclimb starts on Mountain Straight not Conrod. Duncan were you on the turps when you posted up?.
Talking of turps,,,Saturday night sounds like a top idea to me,,,good thinking 99.
hge better be ready buddy or you could always use another car or 2 in the stable.
Come on everybody fill those entry forms out and lets have some fun.
Neil.
ps - with the supersprint - is there any point with the 180 speed limiter???
I guess it depends on your power, I didn't get it with my old gtst.
And last Time I did it there was no-where near 100 entries, and I got 6 runs each day....which is a lot for a hillclimb.
Also, don't forget its only $115 each day, its a great weekend away and not hard on the car.
supersprint is started halfway down conrod (in the dip) so if you do 180 before the kink you'll be a happy boy. easy done
supersprint i only got in about 5 last time, but damn it's fun
hillclimb i got plenty of runs
with any luck, it'll rain. makes for more fun
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
