Does anyone know, or tried the steering rack/mount bushes. I also have seen S13s with alloy bush in the steering rack itself.
Anyone know where to source this gear for an R32? Ive had a look around and its all S13/14/15
Also, Nissan want a fortune for the front and rear tie rod ends. The aftermarket ones are a tad cheaper, but still a lot of money. Have ppl come up with a better solution?
https://www.sau.com.au/forums/topic/138458-r32-steering/
s13 steering shaft spacer is same as r32
one of the guys on here does em for $30
NV N01
just get tie rod ends from a wrecker, theyll do.
EDIT: oh crap, i thought you said steering shaft
Edited by salad
https://www.sau.com.au/forums/topic/138458-r32-steering/#findComment-2578516
Ive got steering rack bushes in mine Roy :(
Old ones were shagged (fell apart as i ripped em out)
Fulcrum suspension do it - Part # SPF2492K (Steering rack Mount Bush Kit) Polyurethane ones
Tie rod ends i got from Pedders - $32 each for the fronts (12mm or 14mm thread size). They have rear as well.
If u want, i can grab you some tie rod ends and send em to you if u cant find em local.
Edited by Bl4cK32
https://www.sau.com.au/forums/topic/138458-r32-steering/#findComment-2578560
  • 6 months later...
I got mine from drift motorsport who is a forum trader.
Fitting took me about 2 hours, mainly because i couldn't get the car up high enough to have any decent working room and the bracket was a tight fit over the new drivers side bush so i couldn't get the thread to catch initially (funnily enough same issue i had when fitting the poly sway bar bushes).
My old ones also fell to pieces as i removed them.
https://www.sau.com.au/forums/topic/138458-r32-steering/#findComment-3078099
  • 1 month later...
  • 1 month later...
I replaced my sloppy wobbly steer rod bush that I bought from NV N01. I painted it black. Excellent fit.
A little tip for when you do it; pull the arm towards you so that you can get a socket on to it, then crack away, spin steering wheel, crack away again. Loosen the lower spline, slide the lower half of the steer rod down and remove the old rubber joiner, fit the new solid and bolt it all up.
Now with slight steering movements I can see the whole rack move side to side so my rack bushes too are buggered. :thumbsup:
No wonder it felt like an old HT Holden. :domokun:
I'll let you all know if there's a noticable annoying increase in nvh due to the solid bush.
https://www.sau.com.au/forums/topic/138458-r32-steering/#findComment-3220855
    • Yeah, all the crude is used for fuels and petrochem feedstocks (pesticides, many other chemicals, etc etc). But increasingly over the last few decades, much of the petrochem synthessis has started with methane because NG has been cheaper than oil, cleaner and easier and more consistent to work with, etc etc etc. So it's really had to say what the fraction either way is. Suffice to say - the direct fuels fraction is not insigificant. Heavy transport uses excruciatingly large amounts. Diesel is wasted in jet heaters in North American garages and workshops, thrown down drill holes in quarries, pissed all over the wall to provide electricity to certain outback communities, etc etc. Obviously road transport, and our pet project, recreational consumption camouflaged as road transport, is a smaller fraction of the total liquid HC consumption again. If you're talking aboust Aussie cars' contribution to the absolute total CO2 production of the country, then of course our share of the cubic mile of coal that is used for power generation, metallurgy, etc adds up to a big chunk. Then there is the consumption of timber. Did you know that the production of silicon metal, for example, is done in Australia by using hardwood? And f**king lots and lots and lots of hardwood at that. Until recently, it was f**king jarrah! There are many such sneaky contributors to CO2 production in industry and farming. NG is used in massive quantities in Australia, for power gen, for running huge water pumps (like, 1-2MW sized caterpillar V16 engines running flat out pumping water) for places like mine sites and minerals/metals refineries. And there are just a huge number of those sort of things going on quietly in the background. So NG use is a big fraction of total CO2 production here. I mean, shit, I personally design burners that are used in furnaces here in Oz that use multiple MW of gas all day every day. The largest such that I've done (not here in Oz) was rated to 150MW. One. Single. Gas burner. In a cement clinker kiln. There are thousands of such things out there in the world. There are double digits of them just here in Oz. (OK< just barely double digits now that a lot of them have shut - and they are all <100MW). But it's all the same to me. People in the car world (like this forum's users) would like to think that you only have to create an industrial capability to replace the fuel that they will be using in 10 years time, and imagine that everyone else will be driving EVs. And while the latter part of that is largely true, the liquid HC fuel industry as a whole is so much more massive than the bit used for cars, that there will be no commercial pressure to produce "renewable" "synthetic" fuels just for cars, when 100x that much would still be being burnt straight from the well. You have to replace it all, or you're not doing what is required. And then you get back to my massive numbers. People don't handle massive numbers at all well. Once you get past about 7 or 8 zeros, it becomes meaningless for most people.
    • @GTSBoy out of the cubic mile of crude oil we burn each year, I wonder how much of that is actually used for providing petrol and diesel.   From memory the figure for cars in Australia, is that they only add up to about 2 to 3% of our CO2 production. Which means something else here is burning a shit tonne of stuff to make CO2, and we're not really straight up burning oil everywhere, so our CO2 production is coming from elsewhere too.   Also we should totally just run thermal energy from deep in the ground. That way we can start to cool the inside of the planet and reverse global warming (PS, this last paragraph is a total piss take)
    • As somebody who works in the energy sector and lives in a subzero climate, i'm convinced EV's will never be the bulk of our transport.  EV battery and vehicle companies over here have been going bankrupt on a weekly basis the last year.
    • With all the rust on those R32s, how can it even support all the extra weight requirements. Probably end up handling as well as a 1990s Ford Falcon Taxi.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
