im planning on getting a 1999 34gtr vspec
i am planning to do the following mods to it
HKS 2530/ or Garrett gt2860R turbos (is there much difference between the 2 apart from price?)
Nismo 600cc injectors
Tomei 260 cams (in & ex)
Tomei Cam gears
Bosch 044 pump
3.5" turbo back exhaust
Apexi power intake
Apexi power Fc D Jetro
Apexi Avcr
Z32 afm, or are rb20 ones fine
is there any other mods i would need to do to support the power im after? no more than 300awkw!
im new to gtr's especially 34's so i dont really know what some of the stock items are capable of
cheers...ben.
https://www.sau.com.au/forums/topic/138515-r34-gtr-mods/
Why the D Jetro when you are using AFM's?
I am really hesiatant to mod my 34GTR.
It drives so nice, starts no problem, idles beautifully, doesnt stutter, no hesiating, etc.......
GT-SS for 300-320kw - ill get these around christmas and see how they go - have heard nothing but good things.
Any news on the GT-ZZ yet?
https://www.sau.com.au/forums/topic/138515-r34-gtr-mods/#findComment-2579593
you'll need some injectors. sard 700cc will do nicely
also, scrap the 044 idea, and get a nismo pump instead.
forget the DJETRO too, just use regular PFC
turbos, I'd go either HKS 2530, or GT-SS (not keen on the generic garretts, but that's just me).
AVCR is old school, looks ricey and expensive. I'd suggest Profec B II would be better for you and cheaper.
for AFMS I'd say Nismo. Means you can use standard intake piping/pod filter set-up and they look standard but support lot's of airflow.
and whatever you do please dont paint it orange! :(
https://www.sau.com.au/forums/topic/138515-r34-gtr-mods/#findComment-2579614
no worries thanks for all the help
looks like ill just go rb20 afm, with the normal power fc, and the gt-ss turbos, with the avcr my mate has one he's selling, plus i had one in my 33 which i thought looked cool, i wouldnt pay the $600+ RRP for them though.
600cc injectors should be sufficient shouldnt they?
id wanna make this car very responsive with some fair enough top end, but my current r33 gts-t has 515rwhp and i dont wanna go to that kind of power level with this one, so thats why i stated 300awkw max, id rather have the supporting mods capable of slightly more so they are not under so much stress..but probs around 280awkw ill be happy with...
i also dont want to go into the whole deal of rebuilding the motor... what is the bottom end strength, before u have to start thinking rebuild?
cheers...ben.
Edited by 2BNVS
https://www.sau.com.au/forums/topic/138515-r34-gtr-mods/#findComment-2579711
If you are only after 280-300kw@wheels, go GT-SS or Garrett -7's. Normal PFC, std afm's, std injectors, std air box, std fuel pump, adj. cam gears, std dumps, front pipes and decent exhaust. Get a good tuner and it will drive/start/idle like stock (surprise!!), but go like 300kw should. IMO, one of the best street set-ups, and only requires an ecu and exhaust change and she will pass epa..
https://www.sau.com.au/forums/topic/138515-r34-gtr-mods/#findComment-2579801
id prefer to get the whole exhaust done, as well as the afm since i can get them for bugger all.. when will the fuel pump and injectors begin to max out?
i was leaning to do cams too as they would help make it more responsiveness, but if they arent necessary then they can wait with the other stuff.... like i mentioned id like the suporting mods to be capable enough of a bit more higher than my actual goal...
that sounds like a good plan, gt-ss, power fc, exhaust, cam gears
Edited by 2BNVS
https://www.sau.com.au/forums/topic/138515-r34-gtr-mods/#findComment-2579839
Tomei Cam gears
Bosch 044 pump
Apexi power intake
Apexi Avcr
cheers...ben.
Ben, as Ash said, if you only want 300awkw, then you want to use the most responsive turbos you can that can achieve that power and the simple answer to that is a set of GT-SS's.
You also wont need a Power FC D-Jetro, and even if you did choose you use one then you wont need AFM's anyway.
My R33 is comfortably producing 320awkw with GT-SS's, Z32 AFM's, Sard 700cc Injectors, Tomei Type B poncams on a VERY conservative track tune :rolleyes:
https://www.sau.com.au/forums/topic/138515-r34-gtr-mods/#findComment-2580062
Locally you'll get stung more than if your had them sent over and got taxed.
I'd use greenline, send a pm to ferni, he will hlep you with greenline, he didnt even pay taxes the lucky boy :)
If your $$$ concious, just get the Garrett -7's as Ben (RPMGTR) said before.
They werent cost effective when i purchased my GT-SS, but now the price is a lot more appealing compared to over a year ago. :)
https://www.sau.com.au/forums/topic/138515-r34-gtr-mods/#findComment-2581223
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
