is it possible to run a series 1 rb25det on a r32 ecu i only ask because the 25 is in a s13 and is allready not using the few things like the speed dependant power steering and the vct has been removed from the engine there is also a few other bits and pieces that were removed.
in short is it possible as i would like the option of a cheap remappable ecu
https://www.sau.com.au/forums/topic/138598-can-a-r32-ecu-be-used-on-a-rb25det/
By the time you purchase the parts, ECU... and change a few things over to make it work.
You'll be close in terms of costings to PowerFC and that sorta thing.
It can be dont, there was a thread about it some time ago, although i cant remember exactly what it was about but i remember reading something.
Try the search button, might take ya 15mins to wade through some threads but you never know
you might be thinking of the thread asking if the rb25 ECU can be used on the RB20 ..
there are injector pins outs different.
also look at the Power FC FAQ on pauls site
http://paulr33.skylinesaustralia.com in documents
it has the pin out change over GIF that i think cubes made with the differences in teh pinouts.
if your realy keen to do it, start in there
just use the RB20 loom and AFM
so long as the AFM and CAS are RB20 units, it will run.
The AFM will simply read more air flow and compensate with more fuel... so if you have turbo injectors (370 compared with the RB20's 260's) youll find it will run too rich.
i found that the knock sensors are the same units, and by visual inspection the CAS looks to be the same (i will know for sure in a couple of days)
oh and just note that the RB20 ecu has no provisions for the NVCS so you will need to go to Jaycar to sort that out;.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
