get a new oil pressure sender or just bang it with something. works for me when it displays really low figures. i have a new sender there just haven't been bothered to change it.
Mine tends to do the same when really hot.
Always has with both the RB20 & RB30DET.
The RB30DET is a totally different motor as well being that it uses a different oil pump etc.
I put it down to when the motor and oil gets hot the pressure sender plays funny buggers.
HPR 40 is the wrong oil. It is too thick to be running through a turbo. The bearing clearances are too small to fit such a thick oil through efficiently. HPR 30 is even too thick.
You should only use HPR 15 for this application.
As for Mobil 1..it is a very good oil but is not good for the turbo cars. It breaks down too rapidly. You will have to do oil changes every 3000 kms.
A semi synthetic 10w30/10w40/15w40 would be perfect for 32 and 33 skylines.
Try not to go lower than a 10 though as a 5w or 0w is too thin and allows more wear when the engine is cold.
Castrol and Penrite are really your best choices with oil in general.
ive found that after i installed an after market gauge and keeped the stock sender in that the stock units have to be faulty because the readings are to different doesn't matter what oil or filter has been used and ive only got 90000kms on the clock
if your concerned about your pressure install an after market gauge and keep the stock unit in so you dont get the warning light always coming on
Why do you suggest a semi synth, and where did you hear about the Mobil1 breaking down?
That kinda goes against what i have read:confused:
Mobil 1 is a good oil. Nice and thin, good sheer strength and made from the good stuff from the beginning (unlike Castrol)
The only down side of it is the high viscosity range which is a bad thing.
Its best to try and keep the viscosity as close as possible i.e 10w40.
Nissan state a 7.5w30 oil to be used in the RB's due to bearing clearances etc. If you go thicker then you are sacrificing oil flow which is used to cool the bearings. This is critical.
Generally a thicker oil is used to bandaid up overheating oil.
Use a good oil cooler and there is no reason why you couldn't use a 10w30 or 10w40 under race conditions.
An oil being too thin 5w or 10w is a load of junk, wear has everything to do with shear strength. :rolleyes:
As my new motor is blueprinted I have found with the running in oil 20w50 Penrite oil pressure was always through the roof.
Once I dropped to the Motul 10w30 it pulled back in line.
As pressure increases, oil volume flow decreases.
Not a good thing I would think.
On start up you are better off with a thin oil. The only constriant is you want to try and keep the vis range close together hence why it is often better to go for a 10w40 than a 0w or 5w-40.
I've done a bit of reading over on bobistheoilguy, this is the way I understand it. :P
Amsoil is one of the best oils along with their oil filters under race conditions. :)
For street duty's I would look at PureONE purulator oil filter due to its high particle filtration. (10microns vs Amsoils 16-17microns) The only down side is it restricts oil flow which is bad under race conditions.
Amsoil has one of the lowest filtration particle size vs flow.
Thats my thoughts. :)
  • 3 weeks later...
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
