which ones did you have the logins for...and where did you get them from???I am curious to know as to who would just give out there password/login details as bidding can be done online...and its all in kanji...so you could buy as much stuff as you wanted to on someone elses account by mistake if you dont understand kanji...and there is a cancellation fee for accidently bought vehilce of 80,000 yen
https://www.sau.com.au/forums/topic/13860-r31-gts-2-door/#findComment-276202
i had my own for certain sites... cant even remember the auction site it was for but it was a major one which gave u access to bid at all the major auctions across Japan.
I spose i could just ask mark if i could register under his business name if he doesnt already have one.
https://www.sau.com.au/forums/topic/13860-r31-gts-2-door/#findComment-276217
nah not like that.... it would come up with all the vehicles that were going for auction on that day and u would put fwd the most u would pay etc and then someone in Japan would do the biding at whatever auction the car was located at for a small fee. Or u could do it the satelite way but i didnt have that obviously and couldnt iew that.... problem is now u have to have a proper business ABN to register now where as a few years back u only had to put down the location and name of the business u were running/working for and they actually check it all out... so i cant just re-register
was good for finding out how much cars were going for and what was coming up at the auctions.
https://www.sau.com.au/forums/topic/13860-r31-gts-2-door/#findComment-276237
this one was a pretty well known one... and as it had the satelite thingo it would be hard for them to hike the prices... unless of course u were biding from the only option i had :) which was by selecting the car then filling out the form.
stuffed if i can remember the name of it tho...
https://www.sau.com.au/forums/topic/13860-r31-gts-2-door/#findComment-276252
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
