Hi Guys,
I've had some issues with my 32 gtr. Mods include: GT 2860R Turbos, Cooler, Splitfire coils, PFC. Currently making 275 @ all four.
I've had some severe missing issues with the car lately. It got to the point where the car was running constantly on 5 cylinders, even on idle. I was getting knock levels up at around 105!
I took it to my mechanic and he changed spark plugs, tested coils, changed ignition amp, cleaned AFMs, replaced the wiring harness, comp tested motor. Car was running fine for about 30mins before it started again.
I put in my old ECU, took the car for a drive and after about 30 mins it started doing it again. I put the ECU into diagnostic mode and error 45 came up - injector leak.
So what exactly does an injector leak mean?? Do i need new injectors?? Could it be fuel pump??
Any help would be appreciated. ;)
Cheers
https://www.sau.com.au/forums/topic/138638-ecu-code-45-injector-leak/
Its means the injector is leaking... Probly one of the o-rings is split.
Im not sure how it would recognise this fault, maybe a big vary in one of the inj duty cycle?
The knock sensors can pick up noise from the missfire and log that it was detonation, And In your case it sounds like the spark plugs/plugs are foulded.
Pull the injectors out replace the o-rings in all injectors, even while their out get them flow tested/cleaned make sure theirs nothing wong inside the injector - I wouldnt think this is common.
Also if it was that bad, change the oil... fuel in the sump = spinning bearings!
See how you go!
No such thing as error code 45 according to the R32 GTR factory WS manual, you'd better re-check. In any event the stock ECU diagnostics aren't set up to detect injector leaks as already suggested.
Edited by SteveL
id be surprised if the ecu could detect injector leak also, it would have no way of knowing. read the powerfc faq in my sig, theres a known misfire bug in the r32 gtr powerfc and it outlines a working fix for it
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
