Hey guys just joined up and did a search, no results so here goes.
Looking at a R33 on this forum and need to know ball park figures for fuel economy.
I have never owned a boosted car before so do not really have a good grip on fuel consumption for such a car.
Also anything to look out for when buying one (set on a R33) such as common faults from production etc.
Thanks guys
Joel
https://www.sau.com.au/forums/topic/138646-r33-gtst-fuel-economy/
There have been a few threads on this. Mine did about 14L/100km in the winter on the stock ECU (with intercooler, exhaust, pod), now does around 12.5-13L/100km and the only reason i can give is hotter weather. Stockers should do 10-11L/100km from factory specs. A Power FC or other aftermarket computer helps lower fuel consumption on modified cars back to near stock when cruising.
There's a thread here for what to look out for when buying a Skyline.
Edited by govich
fuel economy depends on how you drive it. i drive rather 'spiritedly' and i get about 16-17L/100k. i have full exhaust, pod, frount mount and 14psi. that is city driving. on the highway (even if its just 80kmh zones) it drops to about 11L/100k.
R33 GTST
mild hi-flowed turbo @ 1bar, PFC, fuel pump, reg, full 3" exh, pod ~210rwkw
Consistent 450km/55L - 12.2L/100km
Highway driving ~600/55L - 9.17L/100km
Edited by Lazy-Bastard
lazy-bastard: thats mad fuel economy, my car struggles to see ~340 to a tank and thats normal everyday driving. Will my fuel economy increase by heaps with a pfc?
my brother has spoken to a few drifters and they get consistand 400+ to a tank even though they have over 250kw.
i think its tune dependant i think. Im running 209kw on 12psi and im on around 11-12 psi everyday, fuel economy is poor. I have been told by tuners and others that my fuel economy will be heaps better with 250kw and a pfc.
My car had an SAFC2 when I bought it and I was getting about 400ks/55L, so the PFC tune did improve economy a bit.
fair enough, i think if you have a conservative tune, then you will see good km's to a tank. Instead of dumping a whole heap of fuel for no reason, you use every bit of fuel that is allowed in.
1998 R33 gts25t manual completly standard, i could get 500km for a full tank driving it like a granny, i normally get about 200-240km from half a tank of 95 octane depending on how it drive it.
I got my SAFC II tuned and i managed to pick up about 50 ks in town, if i drive it now i would see 400 km in town out of 55 liters but highway is only about 500 if driven nice. I have already changed the O2 sensor and makes no differance.
On average i fill up with 35-40L and get around 350-450k to a tank depending on the type of driving i am doing
Mods are just a exhaust & air filter
I read somewhere that they are meant to do 9L/100k....
I get around 14-15 l/p100k's around town if i drive carefully.... If I hammer it, it can be as high as 19!!!
Just did a run from Cairns to Cooktown and it averaged 14.5. That was sitting at 130kph-150kph (open roads with no-one on them - just gotta watch for cows and roos)
On the way home I sat 110-120kph and I think that has improves it to around 12....
That is in a series II R33 with exhaust and 10psi.......
  • 7 months later...
Guys when doing highway trip i dont get much more out of a tank then if i am city cruising..
I get about 380-400km from 50 liters in the city pretty consistantly, but do a 200k round trip on the highway in there too and am lucky to see 420-430 from 50 litres.. I would have expected above 450km's from 50 ltrs.
Is this a sign my o2 sensor may need replacing, or is this common for a skyline not to get good highway economy.. This is my 2nd r33 and both cars were the same.
Series 1 rb25det exhaust, cooler, pod, 8-9 psi, .8mm copper plugs which are newish...
