Mods:
10psi
3" Kakimoto catback
FMIC
K&N Pod
BP Ultimate
http://img.photobucket.com/albums/v54/xeno..._21/dynorun.jpg
Pretty well spot on i had exact mods dif names of coarse but i got the exact same well close to it maybe 1-5 + rwkws out of the tune, finish the exhaust off for better results, i got 178.9 out of those above mentioned mods.
dam it compear that to my curve, for some reson i have a very flat curve down low, and then a massive increase. No one knows what is going on. the boost is all over the place, the contrtoller decide to pack it in.
mods, 3" dump and exhaust, FMIC Safc II, Walbro Pump, HKS pod, fuel reg.
well my coild suc aswell, but i sikaflexed all mine and it helped a lot, but the gap is down to .7mm anything biger and it misfires, i desperatly need new coils. At the momnet i had .75mm and it's starting to missfire again.
Mine didn't misfire or anything, but this morning i looked at the sensor volatge and at 11-12 psi she is DEFINATLY hitting 5.1V on the airflow, buga.
So lookes like a two stage controller for boost and a tuned ecu with r&r taken off.
bonnet 'up' = inflated power figures.
bonnet 'down' = more realistic power number.
The difference varies from car to car but, you drive with the bonnet down not up.
Who cares, as long as you run bonnet up or down consitently. :rolleyes:
(Sorry for the nagative post...I'm shitty coz my dyno run today showed me that my baseline power run two months ago had inflated figures. I HATE THAT!!! 2 grand and 2 months on mods and apparently I only gained 2KW ARRGGHH!!!!!!) :laugh::laugh:
Who cares, as long as you run bonnet up or down consitently. :P
(Sorry for the nagative post...I'm shitty coz my dyno run today showed me that my baseline power run two months ago had inflated figures. I HATE THAT!!! 2 grand and 2 months on mods and apparently I only gained 2KW ARRGGHH!!!!!!) ;):(
good for you. Don't think about it , I heard thinking hurts your brain.
Is your car faster? Is it more fun to drive? if the answer is yes to both questions then who cares about the dyno results?
Unless of course you are a 'dyno queen', in which case feel free to cry into your dress.
    • Everyone is too used to learning from places like HPA "how to tune" and what to expect at what point, rather than being able to see "The computer says I'm in cell with Row = 8, column =4, and I can see my fuel is lean, so lets add more" Everyone wants "real units", which helps for someone picking it up for the first time and seeing how bad the tune is if they're not used to touching it.   However, I think for most of us who want to play with it, you're 100% right, we're only needing to learn about it for OUR CAR. Which makes it great, and we don't need to care what the real values are, we just need to know which cell it is, that's causing the lean or rich point, or that we want more ignition timing or less. But again, everyone wants everything super you beaut and nearly self tuning, with VE maps, and a billion compensations...   Though then there's me over here when I'm doing reverse engineering work just reading data in hex format that most people couldn't work anything out from. Yet I can see what's going on.
    • Um. No. Since Matt introduced the TIM it has become a lot easier to deal with the consequences of changing K for AFM and injector swaps. Then, tuning is a f**king doddle. No-one needs to know or care how many grams of air are flowing or any other bullshit. Need more fuel in a cell? Add more fuel. Need more timing in a cell. Add more timing. Need to adjust any of the other tables for warm up and so on? No harder than anything else. Sure - it's not an ECU system for starting from scratch on an arbitrary engine. But then.....it was never supposed to be, not recommended for, and almost never used that way. So.... On your engine, in particular, Nistune/Nissan OEM is about as sophisticated and difficult as banging 2 rocks together. Those ECUs are primitive and simple. There is nothing difficult there. I learnt Nistune from scratch, created new maps with extended axes, interpolated/extrapolated the original maps onto them and tuned my RB20 (basically the same ECU as your 26 ECU) all by myself, more than 20 years ago. And that was long before even TIM.
